Question about Kitchen Ranges
REPLACEMENT PART FOR THE DO IT ALL KITCHEN WONDER THE TALL CONTAINER PART NEED REPLACING
The tall cylinder container has the spindle broken and I would like to replace it
  • cornish_anth Nov 01, 2012
    Obviously did not understand the question
SOURCE: Harley Rdkng FLHPI police seat air suspension mechanism removal.
There are two screws below the rubber stem fixed it to the frame. You can hardly see them from any angle but can reach them through the two round openings next to the stem. Use a small wrench, through the openings, to access and remove the screws, then you can remove the stem. However, keep the entire police seat assembly since you might want to put it back like what I am doing now. I tried serveral Harley and other brands seat, high or low profile, and found the police seat is the most interesting seat to ride with.
Posted on Apr 14, 2009
SOURCE: Hinari cafe continental Mod. EC2 replacement glass coffee holder.
Have you tried the helpline number in the instruction manual? 02087 873111
Posted on May 25, 2009
  • 2072 Answers
SOURCE: waste toner container replacement
Yes you can. But there is a window at the top of the bottle . There is a sensor that looks through that window to sense toner in it. It is a small area about a half inch high and quarter inch wide that bulged out of the top of the bottle.
Poke a hole in it, clean it with a q tip and reseal the opening you make .
That should do it.
Posted on Jul 02, 2009
SOURCE: Dishwasher soap container spring is broken
I too thought my soap container spring was broken- I filled the dispenser with soap but then couldn't slide the circle back shut.
But then - EUREKA- I set the dishwasher control back into "off" position and lo and behold, I could now close the little round door! Make sure you verify that BEFORE you spend $$$ on new parts or a repairman!
Posted on Oct 14, 2009
SOURCE: GE Blender (169188) glass container: I broke the
I have a glass container...
Posted on Feb 24, 2010
Need spindle and hand wheel for gate. bought at a yard sale and it is missing one.
We do not have parts. We just answer questions.
Try Googling the manufacturer, maybe they have replacement parts.
Apr 19, 2015 | Top Paw Extra Tall Pet Gate with Small Pet...
Top paw extra wide gate
Contact customerservice@carlsonpet.com or 952-435-1084. Top Paw Extra Tall Pet Gate with Small pet Door item: 10957722, UPC: 73725727486. Replacement hardware kit includes four spindle rods, four wall mounts and four mounting screws.
Jun 10, 2014 | Top Paw Extra Tall Pet Gate with Small Pet...
Need replacement parts for tall pet gate
I have the same gate and have the paper work that came with it.
Top Paw is Carlson Pet Products, Inc. Their # is 952-435-1084
Dec 01, 2013 | Top Paw Extra Tall Pet Gate with Small Pet...
I need the same, but this is the best I can find but not sure if will do the trick for the Top Paw tall gate I have. Did you find a solution? http://www.gates4pets.com/bindaboo-pet-gates/gate-accessories/replacement-hardware-parts-for-gates-white.html
I need a Dianz cbb60 mkp sh 60uf capacitor for a log splitter. Dianz does not carry them anymore.
TITON PRO 370 is the substitute capacitor you need. It is the only one that will fit in the switch box. (TRC60)
60MDF, 2" dia, 4 7/8" long, Motor run capisator
Mar 27, 2012 | Heating & Cooling
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
I can't get the brew group out of the machine. It seems to be jammed.
Brew group stuck?
Close service door and insert only the tall grounds container. Tilt it so it fits in under the flat coffee pat rejection scoop on the left hand side of the brew group as this is likely to be sticking out. The grounds container has a metal bit in the back that affects a magnet reed sensor.
We are trying to fool the machine into stopping at the correct location. Turn the machine on. The drive spindle should rotate. As soon as you can easily remove the grounds container, turn the machine off. You should be able to remove the brew group. The idea is to get the drive spindle (part 22 in the parts diagram) in the correct position so the water inlet in the rear of the brew group can clear the pin boiler (part 10).
How to realign/reset the machine - is another problem i am working on.
Jan 17, 2011 | Saeco Odea Go
V= LWH (w)
policarpio_c,
I am uncertain of your question; however, I hope this answer helps you:
V is the VOLUME of a container, such as a cardboard box or a bottle (how much does it hold) in terms of "CUBIC" measure.
L is the LENGTH of the container from left to right
W is the WIDTH of the container from front to back (or the side)
H is the HEIGHT of the container from bottom to top (how tall it is)
The container's VOLUME (how much it holds) is determined by multiplying:
VOLUME = LENGTH x WIDTH x HEIGHT
V=LxWxH
V=LWH
DO you see what I mean?
If the box is 10 feet long, 2 feet wide and 1 foot tall, then
V=LxWxH
V=10x2x1
V=20 cubic feet
If you need further explanation, please add a comment and I will answer you.
Thanks for using FixYa!!
-Gort.
Oct 05, 2010 | Xpressions Media High Achiever Algebra 1...
Saeco odea go. the brew group is stuck, i cant get it out
Turn off the machine - open the service door and see if u can tilt out the tall dregs container and remove it and the drawer. You need to get it past the coffee par rejector flap on the left of the brew group. It sticks out half way into the left hand side space.
Close the door and put in only the tall dregs container. It has a metal bit on the back the releases a magnetic reed switch inside the machine.
Turn the machine on and you should hear the drive rotor moving. As you move the dregs container back and forth, the drive motor should turn. The idea to is fool the machine into getting the water inlet point in the back of the brew group to clear the boiler pin in the back of the machine so the brew group can be removed.
Jul 04, 2009 | Saeco Odea Go
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
