Question about LG Kompressor Upright Vertical Cyclone Vacuum
My lg kompressor motor is vary hot - LG Kompressor Upright Vertical Cyclone Vacuum
Parts
Hi, it's Allie from Crucial Vacuum!
The agitator, also known as roller brush or brushroll, is located in the floor base.
You can purchase direct your replacement agitator, filters, and belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/lg-kompressor-luv200r-luv300b-roller.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Aug 18, 2014 | LG Kompressor Upright Vertical Cyclone...
Suction
If the motor comes on then either the shaft connection at the fan is loose or the belt to the beater bar is bad.
Jul 12, 2013 | LG Electronics Kompressor Pet Care Upright...
Lg Luv parts list
please go to this web page for to find the parts:
http://www.lg.com/us/support/find-parts
God bless you
May 09, 2012 | LG Kompressor Upright Vertical Cyclone...
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
Suction cuts out, no clogs found in any of the inlets. It's an LG V200R, 4 months old. Returned it to LG twice and it still happens after a couple of uses. Is this a design flaw in the vacuum? Do you...
I bought the lg kompressor 2 mo ago. Made hissing sound and no suction to canister, but the hose had good suction. The inlet was clear, but there was a clog up inside the vacuum between the inlet at the beater bar and the lower hole that empties into the canister(very hard to find). Use a wire hanger to clear it out. just keep jamming it up there and it will clear eventually. There is a clog somewhere, you just have to find it.
Sep 04, 2011 | LG Kompressor Upright Vertical Cyclone...
Is there a manual for installing new drive belts on my LG Kompressor - we've had it for less than a month and the belt broke. I ordered 2 replacement belts and the new one doesn't work and the brush won't...
You've probably figured this out, but my luv200R had the same problem. The belt broke, I changed it and it still didn't spin the brushes. Turned out, the roller has bearings on either end and one of the bearings was bad and wasn't letting roller roll. So the pulley would spin against the belt and heat up and break it again. I took the bad roller to Sears where they had a new one sent to my house free of charge since it was less than a year old.
Mar 03, 2011 | LG LUV200R Bagless Upright Vacuum
Are there any stores that carry a belt for the LG Kompressor? such as Sears or home depot?
Absolutely, Crucial Vacuum has all the LG replacement parts you need. For the vacuum belt, here is the link: http://www.crucialvacuum.com/LG-Kompressor-Vacuum-MAS61842501-Belt-p/lg_vacuum_belt_5eph271.htm.
Jan 28, 2011 | LG Kompressor Upright Vertical Cyclone...
Need a belt for Kompressor vacuum. Micro-V=5EPH271
I NEED A LG LV200R BELT Kompressor vacuum. Micro-V=5EPH271
Jan 25, 2011 | Vacuums
LG Kompressor Upright Vertical Cyclone Vacuum Logo
Top LG Vacuums Experts
Think Crucial
Think Crucial
Ed Mac
Are you a LG Vacuum Expert? Answer questions, earn points and help others
