Question about Linksys Wireless-G WRT54G Router
Linksys router is not working - Linksys Wireless-G WRT54G Router
  • 4 more comments
  • four5s Feb 04, 2009
    Linksys Wireless G WRT54G will power on but will not connect to internet. Have Windows XP and Motorola modem SB5100 with highspeed cable ...was previously working but stopped and can't get it to work now.
  • Anonymous Feb 07, 2009
    my linksys wrt54g does not connect to the internet when when conneted to my motorola sb5101 modem. the wlan light blinks intermitingly when conneted to modem. the modem works fine without the router
  • Anonymous Feb 13, 2009
    linksys router is not working
  • chmac Feb 17, 2009
    My Linksys WRT54G was working fine until I inadvertantly unplugged it while moving components.
    I have good DSL connection without router connected. Have used Linksys setup disk several times, following instructions meticulously, to try and get router going.
    All appropriate lights on modem and router are lit and steady, but cannot connect to internet. Start/Control Panel/Internet Connections/Status says that I am connected.
    Attempts to connect to router web base page via ethernet, using 119.168.1.1 results in message: "not connected." Diagnose connection Problems says I'm not connected. I have moved cable to all four plugs on router to no avail. With each move, I get light for that plug.
    They shoot horses don't they?
  • Michael Ward May 11, 2010
    more info is needed to solve problem
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    "not working"?
    like - not power up?
    like - no connection to the
    internet?
    - it would be a really good
    idea to let us know what it "doesn’t do"
    /Teis
Router no work wifii
What is blocked?
Please explain in detail.
If your router is not working then I will suggest you to reset the router and reconfigure the router.
create a new wireless network and see if that works.
See How to setup Linksys router without CD.
Watch video:
How to reset Linksys router
Feb 04, 2012 | Linksys Computers & Internet
My wireless router isn't working
I think you should reset the router and reconfigure it.
If the wired computer is also not working then I think you need to reconfigure it for sure.
See How to reset Linksys router.
Watch.
Feb 03, 2012 | Linksys Computers & Internet
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
Routers
Yes, this will work fine on any operating system Like Vista , all of the new Linksys router now like this one is already made to work with Vista operating system....
Hope that helps........
Oct 05, 2008 | Linksys Wireless-G WRT54G Router
I cant get my new wireless N linksys WRT310N router to work
First reset the router by pressing the reset button for 15 seconds and after resetting it run the setup CD fo it to reconfigure the router, if you don't have the setup CD better contact Linksys tech support number and let a tech walk you through in manually configuring the router, this is the number for Linksys 800-3267114...........
Jun 18, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Linksys Wireless-G WRT54G Router Logo
918 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
