Question about Goodman Heating & Cooling
I have a Goodman heat Pump. The model # is PH036-10. I haven't used the air or the heat in a couple of months. I went to turn on the heat and everything came on. After about thirty minutes I check
  • Chris Godfrey Nov 10, 2012
    Mr. McElhenny thanks for your response. I had a couple of more but they thought it was a gas furnace. I have determined 1 limit switch needs to be replaced. The only problem is that the numbers have been worn off all three of them. Can you tell me how I could figure out which one I need to get?
    Also, the roll out switches. I can fined anything with a reset button on it. The limit switches where on the right side of the heat pump where all the wiring is located. Can you give me a description of what I am looking for? Also, I am going to replace the blower motor. Is there a certain one that I need to buy. Are can I just get one that the heat pump has in it? (1/3 HP Vt. 208-230) The blower has never been good. Atleast , you have to hold your hand down by the vent to feel air coming out. Can I purchased a 3 speed pump just has long as it has the 1/3 hp vt. 208-230?
SOURCE: Climate Control Blower motor stopped working
I had the same problem with my 2000 Mercury Grand Marquis. I ended up replacing the blower and the resistor which is on the passenger center side of the firewall tucked in where it is hard to get to. Everything worked fine for about two years. It just went out again here about a month ago. I am going to try to replace the resistor again, but I am wondering if it doesnt have something to do with the climate control switch. I do not want to replace the same part every year or two, so if anyone has a idea of what could possibaly be the bigger problem, please let me know.
Posted on Nov 22, 2008
machtcl1
  • 61 Answers
SOURCE: Goodman furnace GMPN080-4 Getting 4 RED blinks/Open Limit Swtch
You have a limit switch located in the furnace (a little bigger than a dime and located near the center of the front panel, sometimes the switch is mounted to a small fiberglass board) . There will be two wires going to it. They sometimes trip so often that they fail to automatically reset(due to dirty filters or undersized ductwork). You can SHUT OFF POWER TO THE FURNACE, then remove the two screws holding the switch in the furnace, pull the switch out of the furnace and tap on it and wipe it off.
The switch may work a few more times but should be replaced with the same size and type. You will see some rating printed on the switch somewhere. Write down all the numbers and get a replacemet from a furnace/AC supply house. If you have a meter and know how to use it you could check the switch for continuity.
Sometimes just a tap on the switch will get it going. There will also be a couple of rollout switches that could be tripped. They have little buttons on them to reset them. If they trip it may have other issues to be solved.
Hope this helps!
Matt
Posted on Feb 01, 2009
tjt3
  • 44 Answers
SOURCE: gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Posted on Mar 24, 2009
  • 659 Answers
SOURCE: New motor runs but doesn't blow air through the registers
Is the blower wheel turning? Did you by chance have to remove the motor from the blower wheel to work on it? If you did, did you put the blower wheel back on in the correct direction of air flow? Also, did you put the correct capacitor back on the unit so it can get up to the required rpm's? These are things that you will need to check for. If the motor is running and the blower wheel isn't and the wheel is tight on the shaft, then you will have to replace the motor. The brushes may be bad on the unit and it's not turning the shaft. Hope these ideas help.
Posted on Apr 10, 2009
daddyo742001
  • 70 Answers
SOURCE: American Standard blower will not run
Sounds like motor has failed. If the red light is blinking it may be telling you what is wrong by the number of blinks. It maybe locked out for some reason or loose wire. Try turning off breakers to inside unit for 5 mins and try again, this may reset unit. But it sounds like a bad motor or circut board. Try running with stat in on position instead of auto in cooling mode.
Posted on Jun 28, 2009
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Goodman package unit heat strips will not turn on
Put meter probes at in put terminal of the element if you read 220volts that mean your relay is good. if you got it there use amp meter on one leg of that element. You should read some amp draw there but if there is no amp draw it mean the element broke.
Nov 29, 2013 | Goodman Manufacturing Goodman GPH1530M41...
Fan keeps running
the safety built in is when the sequencer goes bad it turns on the fan so it doesnt create a fire. replace sequencer. to make sure check amps if over 6 or7 amps sequencer is faulty
Jun 08, 2013 | Goodman Heating & Cooling
Cost of a tune up for 95 mercury tracer
There haven't been Tune-Ups in a couple decades
Your asking about spark plugs & preventative maintenance
Ask a repair shop, everyone on this site is at home like
you, & just uses the site like facebook
Jun 25, 2012 | Cars & Trucks
I purchased a new Goodman AC/Heat inside and out side units, am getting ready to run the wiring to the sub panel, Not sure what wire to use from the main braker box to the sub box have found different...
http://www.encorewire.com/docs/amp%20voltage.pdf is a diagram of what size wire and type you need for different amperage. As you can see the 10/3 recommendation is good for a maximum of 30 amps in copper and 25 in aluminum.
I haven't found the CKL36AR36 installation guide, so I don't don't know which circuit breaker size you need to install. But it should be listed in your installation guide that you got with your unit. Make sure that you have the correct disconnect within 6 feet of the unit to meet code.
Jul 12, 2011 | Goodman CKL36AR36 Air Conditioner
Im installing the air conditioner.goodman model number ssz140301ae. Didn't come with orfices (flow eaters) put in ones I found. Have a number 085 on them. Haven't turned it on ya.need to know. Size...
You need anything between 060 and 065 for your model. The 085 is way to big and will usually cause problems with the refrigerant flow. Hope this helps and good luck!
Jul 05, 2011 | Heating & Cooling
I HAVE A GOODMAN CPL E30-1 , HOW DO YOU CHECK THE HEAT STRIPS ARE WORKING ? WERE WOULD CHECK THE TEMP AT ?HOW CAN YOU TELL IF THE HEAT PUMP IS WORKING RIGHT .WHAT IS THE COMMON THINGS A TECH SOULD CHECK...
First, you need to get the spec sheet for that unit from www.goodmanmfg.com, go to bottom, click on Partner link, then put in goodman for id, dealer for pass, go to InfoFinder in the Toolkit. under model, put CPLE, under lit type dropdown put spec sheet. Click on the RED SS number in the fourth column. In the spec sheet, print out the Expanded Heating Data sheet for your CPLE30. It shows the outdoor ambient temp, follow that column to the bottom and it shows the pressures you should have. They are very very close it unit is working correctly. It also has a DeltaT for airflow. So, now you can put stat at 1 degree differential so only heat pump comes on and check temp rise and pressures. If both pressures are low, you have lost some charge. As for heat strips, turn stat up 2 or more degrees or put it in Emergency heat. Then the strips should come on....sequencer may delay stages. Then you need to use amp clamp to see if individual heat elements are pulling amps. In E heat, you need to go online and get a CFM/Kw temp rise chart. It will show you what your temp rise from return to supply should be at your cfm with the amount of heat you have..i.e. 10kw, 15kw, etc. If it is cold out and your heat pump is running with no aux heat, the temp rise will get lower as the outdoor temp falls, so alone it will not be able to keep up.
Jan 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Will not go into defrost
Did you change the thermostat in heat pump? or did you change it when you replaced the board?
Dec 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
196 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
