Question about Maytag EPIC MFW9600S
Maytag mfw9600sq1 front load washer - when draining the pump keeps running until the Sud then F02 error is displayed. I have replaced the pump per the service guide, but the problem persists.
  • David Nov 01, 2012
    I wanted to give an update to my issue with the F02 error. After replacing the pump I ended up replacing the pressure switch and this solved the problem. Hopefully this info will help another DIY home appliance repair person!!
5 Suggested Answers
  • 744 Answers
SOURCE: my front load washer displays an f28 error code
See the FixYa post:
http://www.fixya.com/support/t800390-f28_error
Posted on Mar 29, 2009
  • 65 Answers
SOURCE: I have a Maytag front load Mod. # MFW9600SQ1. When
This is actually a fill error, it appears when the tub should be filling and is not being sensed. Make sure that both hot and cold water is turned on. Since you do see water coming into the tub this is an issue related to your pressure switch. It sounds odd but this can also be caused by a siphoning drain so check to make sure your washers drain hose has only a little over a foot into the drain otherwise this may cause it to siphon and throw up the same error. If the water is on and the drain hose checks fine then I would guess your gonna have to replace the pressure switch but right now my money is on the drain hose being shoved to far down in the drain pipe. Hope this helps.
Posted on Jan 30, 2010
Testimonial: "It remedied the issue :) Thanks"
rickyrt441
  • 4399 Answers
SOURCE: I have a maytag front load washer model number
Thanks for choosing FixYa and welcome to the site. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 05, 2011
KevinWhite
  • 1902 Answers
SOURCE: Hello My Maytag black front
Hello & Welcome to FixYa
F02 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Aug 07, 2011
My washer keeps saying SUD. what is wrong?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 31, 2011 | Washing Machines
My front load whirlpool washer keeps saying sud & f02 so i cleaned the pump filter&drian, so even with out soap it still said sud. thanks for your help
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F2 code keeps appearing and then beep occurs and washer stops during random cycles. Have had washer repaired numerous times.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
cleaning a drain pump Check drain pump for foreign objects
• If the above does not correct the problem replace the pump
Oct 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM9000 front loader Gives SUD on display then F02 and beeps.
it is a Long Drain error
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank You
Sep 10, 2010 | Whirlpool AWM9000 Front Load Washer
Washer will not wash complete load. flashed f02, water not draining
F02 stands for long drain
you can press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
you might want to check..
• If the above does not correct the problem most probably you will have to replace the pump
Jul 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
Mar 25, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My washer is a whirlpool front loader. It keeps
F/02 Long Drain
Jan 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
F02
Potential Causes
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error codes
Potential Causes
Feb 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag EPIC MFW9600S Logo
182 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
