Question about Smeg Refrigerators
Pierced hole in smeg freezer is it fixable
Small hole to back of freezer but gas is leaking from freezer
The only repair for this is to replace the evaporator, this requires serious technical skill in
refrigeration,
Usually this type of repair costs more than you will want to spend, it is not
covered by any warranty I know of.
Most techs will not want to attempt a repair of this nature due to the near impossibility
of getting all the moisture out of the system, and the very real likelihood of a service call back.
In future Only use hot water to assist in defrosting, or let defrost naturally before putting back into service. Never use any device to pry or poke at the ice.
Posted on Jan 03, 2009
How can i fix my freezer because iv pierced a hole in the wall?
You can't fix it if the hole in the wall has pierced the refrigeration tubing inside
Apr 26, 2014 | Refrigerators
Hi I have a smeg fridge freezer and the I think I have accidently pierced it whilst defrosting, and the gas has leaked out. Am I still going to be able to use the fridge?
no and somewhere in the directions it will say do not use sharp objects to remove ice. call a service man but probally will cost high dollar to fix. best thing to do is get another one unless you are in love with this one.
Apr 17, 2011 | Smeg CR330SE 1 Bottom Freezer Refrigerator
My old Electrolux Model FI22/10B (frost free freezer), started freezing up. When i defrosted it, it had holes in the top part of the fridge and gas started spraying in my face. My landlord is now holding...
What you were looking at was the evaperator. If it was evenly froze up, it had a defrost problem. If it was just an iceball then it had a leak in the system.
Mar 30, 2011 | Electrolux Refrigerators
Freezer no cooling and compressor continues running.
low on gas has leaked check acces tube or valve or any solder joints for oil traces as this is common also check if someone has pierced inside the chest to defrost freezer as this would probably dammaged the evaporator
Aug 28, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Smeg fride freezer leaking
HI Mark,
The evaporator drain is blocked causing the defrost water to pool, freeze and then leak onto your floor.
Clear out the freezer, then use a hammer to break up the ice on the floor. Now remove the rear panel. You'll see more ice build up. Don't use the hammer on it! (Too close to the coils for comfort) Use a hair dryer to warm up/melt the ice below the coils.
You'll see the drain hole now. Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
SG
Mar 27, 2009 | Smeg FA561X Side by Side Refrigerator
Haier Fridge and Freezer
The compressor and Freon are all one sealed unit,never heard of a separated system. by turning it on you will just drain the rest of the freon.
Feb 16, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Hissing freezer
Hi criago
I am very sorry to say that you have pierced the coolant tubing, the hiss you here is the coolant gas escaping. Your Fridge Freezer may be unrepairable because it is very hard to get into the area concerned.
Sorry to break the news to you.
Jun 15, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerators Logo
356 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
