Question about Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher
Installation instructions of maytag dishwasher MDBH945AWW
4 Suggested Answers
  • 3422 Answers
SOURCE: Dishwasher won't start
If the unit won't start, but "hums", then the motor itself may need replacing (you need to check for 120V at the motor harness). If the control itself is bad, then you would have to replace the control. You mentioned that the door didn't work right - if that is the case, the door switches may not be making contact properly, thus preventing the motor from starting (the door has to be closed properly for it to start).
If you have any other problems please ask me.
Goodluck,
Please don't forget to rate me as fixya
Posted on Feb 09, 2008
  • 4088 Answers
SOURCE: Maytag Dishwasher-MDBH945AWW
About the only things that move in the cabinet other than the water pump is the spray arms. The lower arm should be screwed down fairly tightly (plastic screw), but the upper arm is held in place with a plastic friction plug--it tends to wobble more. Spin both arms by hand to see if either hits something (have the drawers in). The lower arm has metal clips on the ends which may be coming loose. They are just clipped onto the arm edges. Hope this helps!
Posted on Apr 06, 2010
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
http://www.fixya.com/support/t387192-maytag_quiet_series_300_no_power_touch
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from RadioShack.com or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
Disherwasher not rinsing well. Top shelf glasses/cups seem to have food residue. Maytag mdbh945awb
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;;
May 20, 2011 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher mdbh945aww3 does not start washing. the only button that seems to work is the start/cancel and all it does is turn on all the lights.
you have to get the touch pad replaced. my worked for 11 month, got it replaced (3 weeks to get the part), worked for 1.5 month and broke again out of warranty. time to get a new dishwasher and extended warranty. maytag is total c$%p. Everything is made in Mexico. I think even China makes a better product. WOW did I say that?!?!
Jun 27, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Drying cycle doen't seem to turn off ....just seems to cook. Had to turn unplug the unit.
if this is electric dryer your heating element had short to ground cause element to stay on even if the dry turn off
Apr 25, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Apr 06, 2010 | Maytag MDBH945AWW / MDBH945AWQ /...
Will not start
I have the same problem and it turns out that it is the front panel touch pad that cost $185 for the part. I plan to just buy a new washer.
Jan 19, 2009 | Maytag MDBH945AWW / MDBH945AWQ /...
MDB8750AWS
Do you have alot of electrical storms, install surge protectors on all electronic appliances.
was the board and the person installing the part grounded. static can make those parts fail within a few months.
Oct 16, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Oct 05, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Maytag MDBH945AWW / MDBH945AWQ / MDBH945AWB Built-in Dishwasher Logo
74 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
