Question about Universal MX-900 Remote Control
Buttons stopped working
The only buttons that work are the numbers.
  • Kelly Nov 01, 2012
    The remote is the problem, still looking for a solution.
    Top Expert:
  • Universal Master
  • 14,553 Answers
If remote designed for tv, and or other units the mode button may have been pressed etc.
Set to dvd etc instead of one for unit being used on.
The remote can be tested by any shop (usually for free) to see if it is sending a signal......
Posted on Oct 30, 2012
  • 3 more comments
  • Kelly Oct 30, 2012
    Thanks for the reply, but that's not the problem with this remote. None of the major buttons I normally push are working; Off, On, Watch, Listen, etc. The LCD screen started to have some fading also in a couple areas.
  • SD Tech
    SD Tech Oct 30, 2012
    "THE ONLY BUTTONS THAT WORK ARE THE NUMBERS" are some buttons on the remote working and others not?
    Yes, it's the strangest thing. The numbers are at the bottom of the remote (which I never use), everything above the numbers does not work. One minute it was working then the next it quit. They still make a beep like they are working when pushed, but nothing happens.
  • SD Tech
    either its in the remote or the set which receives signals and translates them to certain actions is at fault--one or the other.
    Thanks for your help.
Tip
How to program your RM-V310 Sony Universal
Step 1: Entering the Code Number
1 See the supplied "Component code numbers", and find the threedigit
code number for the desired component.
If more than one code number is listed, use the number that's
listed first to complete the steps below.
For example, if you're setting up a Philips' VCR, you would use
the code number 035.
If your component isn't listed, see "Searching for the Correct
Code."
2 While pressing the SET button, press the
POWER button.
3 Press the button of the component that
you want to set up.
Note
On the VCR, CBL, SAT, AMP, CD, and DVD buttons, "video cassette
recorder", "analog cable box", "digital satellite receiver", "receiver",
"CD player", and "DVD player" are assigned respectively at the
factory. But you can also assign other components on these buttons.
For details, see "Changing the Component Type on the VCR, CBL,
SAT, AMP, CD, and DVD buttons."
4 Enter the component's code number.
For example, if you're entering the code
for a Philips VCR, you would press
5 Press and release the ENT button to store
the code number in the Commander's
memory.
6 Go to "Step 2: Checking if the Code Number Works" to finish
setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works.
For example, press the POWER button to see if it works on your
component .
3 Check that the other buttons of the Commander is operating the
corresponding functions of the component.
You can write down the code number on the label inside the
battery compartment lid.
If the Commander Doesn't Seem to Be Working...
• First, try repeating these setup procedures using the other codes
listed for your component (see the supplied "Component code
numbers").
• If - after trying all the codes listed for your component - you still
cannot get the Commander to work properly, try the search
method described in "Searching for the Correct Code."
These instructions came from the Sony RM-V310 Operating Instructions Manual. To Download the Full manual for FREE click HERE>
on Oct 07, 2010 | Sony RM-V310 Remote Control
Radio was working then went off the eject button works the clock button works but the radio or USB will not work no sound
Hi Steve, If you disconnected your battery then check out the link below for more information or take your registration papers with your licence (licence is to prove YOU own the car) to a car dealer ie: Holden, Ford, Chrysler and ask at the sales office for the RADIO SECURITY PIN NUMBER, You'll receive your Radio security pin number and Radio serial number. These numbers belong to your car and once you have them DON'T loose them because in Australia some dealers charge a fee and some don't.... Hope this helped....CHEERS..
https://www.google.com.au/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=RADIO+SECURITY+PIN+NUMBER
Apr 17, 2016 | JVC Kd-r418 Car CD / USB/ MP3 Player
How do I program the Flexible Outside (CO) Line Buttons? The manual doesn't say!
if you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Jun 09, 2015 | Panasonic KX-T7730 Corded Phone
Buttons make numbers appear on screen
The keypad control board must be replaced in order to address the issue, but keep in mind the part alone is expensive.
Apr 18, 2012 | Microwave Ovens
Code is not working 6000 cd serial number M010539 please can anyone help me
Your Code is: 1481
Insert the radio code by repeatedly pressing button 1 until the first
number of the code appears on the display.
Press button 2 until the second number of the code appears in the display.
Repeat the process on buttons 3 & 4 to complete the code.
When the code is entered correctly press button 5 and the radio should unlock.
It works very well for me
Mar 26, 2011 | Ford Car Audio & Video
My battery was disconnected and now I have to enter the security code for my radio for make it work again! I have the code, but I don't know how to enter it!
You should have the radio pre-set numbers 1,2,3,4,5 & 6 along the lower edge of the unit.
Most stereos are like this:
Example code 4358
Press number 1 button - 4 times
Press number 2 button - 3 times
Press number 3 button - 5 times
Press number 4 button - 8 times
Hope this helps
Lloyd
Aug 20, 2010 | Car Audio & Video
The radio is safe, how to reset again
Turn on radio - the word SAFE will appear in the display. Press th P.SCAN and RBDS buttons simultaneously and hold them down until "1000" lights up in the display.Release buttons.Do not, under no circumtances, continue holding them down or press them once again. This will cause the radio to consider the number 1000 to be the input code.Use station buttons 1,2,3,and 4 to enter the code number on your Radio Card. Use the button 1 to enter the first number 2 for the second number 3 for the third number and 4 for the last number.Once you have entered the code and it shows on the display,press the P.SCAN and RBDS buttons down again simultaneously and hold them down until the word SAFE appears in the display.Release buttons. Soon afterwards a frequency will be displayed.
Oct 03, 2008 | 2000 Audi TT
Changing number for call fwd on KX-T7630
This is against my better judgement, but try this link.
http://www.microtelcommunications.com/linked/tda_operating.pdf
BEFORE YOU DO ANYTHING, PRESS PROGRAM AND THE BUTTON AND WRITE DOWN WHAT IS THERE.
Now you have a manual. Look at the *7 commands on page 191. My guess is the installer put *714x commands under the button, but he may have done some 44 commands via personal programming. You did write them down? The 3rd piossibility is that it references a bin that is programmed as a mobile number...you can assign any 3 digit number in the universe of 100 to 699
as an ICD number that forwards all calls to an outside number.
Anyway, please acknowledge that you got the pdf and I hope it works out for you.
Carl
Sep 19, 2008 | Panasonic KX-T7630 Corded Phone
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Universal MX-900 Remote Control Logo
77 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
