Question about Brakes for Oldsmobile 98
Ac low low pressure, high high pressure
Adding freon and the AC still didn't cool.
    Top Expert:
  • Oldsmobile Master
  • 76,164 Answers
If the pressures on the low side are around 28-34 PSI then you problemis not the AC system not makeing cold air. Read on.
Air Temperature Control Blend Door Failure No Heat or no AC cold air (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Posted on Nov 05, 2012
On my 2006 ac works good when engine is cool, in stop & go traffic it blows hot air & head pressure gets high in ac, car temp is ok what's wrong
How do you know head pressure is high? Do you have an auxiliary electric cooling fan that is not coming on in this situation? It should be in front of the AC condensing coil. There may be a switch tied to the system that is bad. This switch is sometimes activated by the pressure in the high-pressure line to the condenser coil. If there is not enough freon (134a) the pressure will not be high enough to activate the cooling fan switch. I recently added one can to my system and it made the fan run whereas it did not before adding the freon.
Jul 05, 2015 | AC Cars & Trucks
My ac compressor broke. I had a new compressor and expansion valve replaced. It cools a little on high but not enough. Any ideas on the problem?
You need to check the refrigerant pressures (high & low) and learned the reason for the cooling problem-the gauges are the only way you could ever know what is going one with the AC-low pressures (both sides), low refrigerant-high pressure, over charged and not allowing the AC to cool.
Jul 23, 2010 | 2006 Chevrolet Malibu
How many pounds of r134 and how much oil ozs.
somewhere around 1.6 pounds (1lb.14ounces) of R134a if system is evacuated and 3 ounces of oil with new compressor.
keep pressure on the low side around 34-37psi & it should blow snow. Below are normal car AC pressure readings with 134A.
  • Normal readings on high and low side with AC OFF (static pressure) – Depends on outside temperature, but normally is between 80-105 PSI
  • Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI –
  • Normal high side reading ranges from 200-350 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor.
DIY recharge kit:
With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold – STOP don’t overcharge the system.
Thank you for using fixya and be safe.
Jul 19, 2010 | 1994 Chevrolet S-10 Blazer
Air conditioner compressor runs - freon is up to proper level....not cooling??
BOTH High and low readings should be checked to have a better idea of what is going on with an AC system but based on the limited information… the compressor is not engaged or is not pumping. Below are some things I would check;
1. Check the high and low gauge readings with the AC on & set on MAX/Recirculate, middle vents with the engine at 2,000 RPM’s, blower speed on high.
2. Check the vent temperatures with a thermometer from the middle vents, far right & far left vents?
3. What is the outside temperature at the time the readings were taken?
4. Check to see if the condenser fan blowing strong?
5. Notice if compressor clutch is cylcling excessively.
Could be overcharged, not enough air going across condenser fins, compressor not pumping sufficiently… BOTH gauge readings are really needed to get a better idea.
Thank you for using fixya and good luck, keep me posted. Be glad to help you get your A/C running again soon.
Jun 12, 2010 | 1999 Chevrolet Silverado 1500
AC comes on, then shuts down before car is cooled. Compressor activates and blows cool air for about 15 seconds then shuts down.
Low on R134a, you need to have the system recharged. Try to stay away from the do it your self kit that most Auto Parts store carry.
Thank you for using fixya and good luck.
http://www.freeautomechanic.com/airconditioning.html
Jun 12, 2010 | 1998 Cadillac Eldorado
My a.c is not cooling i put freon in and my compressor will only come on every now an then i replaced the switch in the dash but still did not help i did use a jumper wire to my compressor and it...
You may not have enough R134a in the system, or you have over charged the system and your high pressure switch is turning your compressor off when the pressure get's to high.
You really need a A/C gauge set to see of your system is over or under charge. If it's under charge, that's good. A over charged system will cause your a costly repair of replacing a $300.00 rebuilt compressor plus the vacuuming out the system and replacing the accumulator which may have parts from the compressor (bearing).
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s – Ranges from 25-35 PSI – Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI
Don’t assume that if adding little Freon is good that adding a lot is better! Overcharging just a little can decrease the performance of the system and possibly damage the compressor, assuming the blower speed is on high, AC is set on maximum and engine is around 2,000 RPM’s
3. What is the outside temperature at the time the readings were taken? 4. Check to see if the condenser fan blowing strong?
Jun 12, 2010 | 1994 Toyota 4Runner
95 Deville - Low Refridgerant/AC Comp. off
To diagnose problems, an A/C manifold gauge set is needed to read high and low side pressure readings. Avoid adding refrigerant with a simple charging kit like the ones sold at parts stores. Don’t add any stop leak, this can cause problems in the compressor, expansion valve or condenser.
Keep in mind that using an A/C gauge set and seeing BOTH high and low side readings can help in diagnosing the problem when you know what to look for. First, on a 134A system the high and low side service ports are different sizes. AC gauge sets have color coded hoses, the blue color coded hose has a connection that fits on the low side service port and the red hose has a connection that will only fit onto the high side. The yellow hose won’t hook up to anything if just checking the readings; it can be used to connect to a vacuum pump or attached to a refrigerant can or tank.
Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI
Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI
Both low and high side readings are lower than normal, this indicates a cars AC system is low on refrigerant and is under-charged.
If both low and high side readings are too high, this indicates an overcharged system - too much refrigerant. This also can indicate that the condenser fan is not working, is too slow or the car is overheating and heat is transferring from the radiator to the condenser.
Good luck and hope this helps, keep me posted be glad to answer any question you may have. And yes the A/C system on your car uses R143a and there is a A/C pressure switch along the low pressure line or on the accumulator, it looks like a oil pressure sensor with a two wire lead cliped on it.
Jul 02, 2009 | 1995 Cadillac DeVille
Ac compressor took one can of freon will not take other also it still is not cool
You may have over charged the system, An over charged system will also give you poor A/C performance and worst can lead to expensive repair if the compressor get's damaged.
 With the AC on the coldest setting, use a thermometer in a middle vent. Normal vent temperature readings will vary depending on the (ambient) outside temp. The vent temperature should range from around 42-55 degrees in my experience. If normal gauge readings are obtained and the vent air is cold - STOP don’t overcharge the system. The only proper way to remove refrigerant is with a AC recovery machine so if this is being done at home I can’t emphasize enough not to over charge the system. And actually the best way to insure the proper charge is in a system, is to use an AC machine to recover the freon and then evacuate and recharge the system with the correct amount. Most cars have the specified amount on a decal under the hood.
God luck and hope this helps.
Jun 30, 2009 | 1994 Ford Escort
2003 Chevy 1500HD (6.0) Air Conditioner Will Not Cool
a refurbished compressor should be fine and will be cheaper than new, your should also replace the orfice tube (expansion), and the dryer, and the seals at the connection points.
Mar 25, 2009 | 2003 Chevrolet Silverado 1500
Vehicle Parts & Accessories Logo
195 people viewed this question
Top Oldsmobile Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Robert Swatek
Robert Swatek
Are you an Oldsmobile Vehicle Part and Accessory Expert? Answer questions, earn points and help others
