Question about Gaggia Syncrony Compact Digital Espresso Machine
Central unit won't come out
Central unit stuck
KEYS WON'T COME OUT
Hi This is Bishop.Keys stuck in ?????????? trunk,Door,Ignition.Nead more INKO.Also is the car central locking?
Jul 05, 2012 | 2006 Cadillac CTS
Electric door locks won't work
Hi Kim, It would help if you could be more specific. Are you referring to locking and unlocking via a key fob, and if so is it a factory fitted unit or an after sales fitted unit. (if that's the case, have you tried replacing the battery inside the fob?) or are you reporting a failure of the central locking system? If you let us know we'll do our best to help you. Regards John
Dec 12, 2011 | 1995 Buick LeSabre
Had F70 &F71 changed ccu and ui won't power up just beeps
Even after they replacing the CCU and the MCU, I still kept getting the three beeps and the F70 Error... the fix was replacing the front controller boards (where the knobs and buttons are). check your connections also, and that they are in the proper slot.
Oct 31, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
F70 code on washer nothing will work
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I HAVE A CARRIER CENTRAL AIR, THE OUTSIDE FAN IS BLOWING INWARD AND WON'T SHUT OFF WHEN THE FURNACE SHUTS OFF AFTER TEMP IS REACHED
Check the t-stat to make sure that the "fan" switch is st to auto. If not the fan is in the "on" position and is always on. Otherwise, It sounds like your "Central Air" is a packaged unit(Furnace and air all one unit outside the home) and the fan relay inside the unit is stuck. This need to be replaced. It is the rectangular unit with the leads from the fan motor attached to it.
Jul 29, 2011 | Heating & Cooling
Washer won't start.....F70 code appeared It's a Whirlpool Duet
Kevin
Jun 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What does F70 mean?
Kevin
Jun 11, 2011 | Kenmore Front Load Washer
My dehumidifier is not working. The control panel lights-up, but its stuck on 70% humidity and won't adjust down. I took it apart and noticed burnt marks next to the circuit that controls the humidity....
I'd say you're right on target. In which case, although the unit was manufactured my Whirlpool for Sears under their house brand, Kenmore. You can find the part(s) online at Sears Parts Central
http://www.searspartsdirect.com/partsdirect/index.action . If you can do the replacement yourself, you'll really save $$ on labor.
Hope this helped you. Please let me know. Thanks.
May 30, 2011 | Kenmore 54701 Dehumidifier
Open Questions:
See all Gaggia Syncrony Compact Digital Espresso Machine Questions
Gaggia Syncrony Compact Digital Espresso Machine Logo
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
