What should the anticipator setting be in the thermostat fo a mac 1155 heater
Funace is short cycling
2 Suggested Answers
mangofruityj
  • 673 Answers
SOURCE: where can I get a manual for a mac 1155 heating system
Try it from here
Posted on Oct 30, 2012
When in the heat mode the system will start and rune only a few seconds then stop. After a short pause the system will re-start and run ubitl the set temp is reached
Bruce, what you may be hearing is a short cycling of the fan and not a short cycling of the system. The fact that you indicate it only does it once per cycle kinda suggest that. If the ENTIRE unit was shutting down, it could indicate an adjustment in the 'heat anticipation' circuit on the thermostat sub-base was required. The heat anticipator is an adjustible resistor on non-digital thermostats that warm the spring that rotates the mercury bulb to cause it to shut off just a little bit before attaining setpoint...thus 'anticipating' the shut down temp and not 'overshooting' the setpoint.
Too low of a setting and the system will short cycle, too high of a setting and the system will overshoot the setpoint. The typical setting is .4 amp which is where the majority of sub-bases are set at from the factory.
Nov 12, 2015 | Hunter 44860 H Univ. Touchscreen...
Tip
How do I Set the Thermostat Anticipator
If you have an older thermostat that has a heat anticipator in it then there are some things that you need to know about setting it and what it actually does.
First the function of the heat anticipator is to fake the thermostat into feeling the room temperature as hotter than it really is. The heat anticipator is actually a variable output heater inside your thermostat. The amount of heat that it actually produces is very, very small. This heat does, however, make a difference in how the room temperature feels to your thermostat.
If no extra heat is made inside the thermostat it will not react quickly enough to shut off the heating source. This will make the room “overshoot” the set point of the thermostat.
By heating the thermostat up very slightly it then shuts down the furnace or heat source before it actually reaches the temperature set point. This will allow the left over heat to go into the room and raise the temperature to the set point by the time it is all used up.
If you are experiencing wild temperature swings or the room temperatures are either not getting to the set point or going over the set point then the heat anticipator either is not adjusted right or it is burnt out and not working at all.
There are a couple of different types of heat anticipators. They will usually look like one of these.
If your heating is running too long then you will need to adjust the setting to a lower number. If you are not getting enough heat then go to a higher number. All you are changing when you do this is the amount of the heat coil you are using. Make small adjustments to the anticipator and then give it at least a half day before making more adjustments. Small changes can have a big effect if the heat anticipator is working correctly.
You also can set the anticipator by checking the current draw of the system. To do this you need to use an amp meter and measure the current draw of the heating unit when it is running. Then set the heat anticipator to the corresponding number of the current draw. This will at least get you a good starting point and some fine small adjustment can be made from there.
For more advanced digital thermostats there are cycle change features that do what this heat anticipator does in older thermostats. These often incorporate many things in determining the cycle length of the heating. These thermostats will not have a heat anticipator setting.
Like many things when it comes to your comfort, all people feel things a bit differently. You need to make the changes to the thermostat so that YOU feel comfortable. There is no right way it has to be done. Make it work for you and adjust the thermostat so that you are the most comfortable!
http://www.fixya.com/support/r3892721-programmable_honeywell
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3584298-air_conditioning_programmable_thermostat
http://www.fixya.com/support/r3898732-lux_thermostat_500
on Jan 30, 2010 | Heating & Cooling
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
My furnace will not reach the desired house temperature in one cycle. It will run for several minutes, shut off, and repeat. It eventually reaches the desired temp but it take a long time and I feel it...
There are a few different reasons for short cycling of a furnace.
1. Inadequate air flow. Not enough air moving through the furnace can cause it to overheat and trip the high temperature limit switch.
check to see that all registers are open and returns are not blocked.
2 Improper heat anticipator setting on thermostat. Some thermostats have a heat anticipator and too low of a setting can cause short cycling.
4 Partially blocked drain hoses. If the condensate backs up into the furnace it can shut the flame off and then when the condensate drains the furnace starts again. Check all drain hoses to make sure they are clear.
These are just some of the possible reasons for short cycling .
Hope this helps.
Dec 26, 2013 | Heating & Cooling
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
HAVE A BRAND NEW GKS90904CX FURNACE. IT RECYCLES EVERY 2-3 MINUTES.WHAT WOULD MAKE THAT HAPPEN?
Hello
In the thermostat is a anticipator which controls the cycles.
Either the anticipator is set wrong or the thermostat is bad.
Feb 02, 2010 | Goodman Heating & Cooling
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Furnace kicks on every 15 mins
fuanace may be oversized and is short cycling it heats up house to fast it is better when they run longer
Dec 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
