Question about BenQ PE7700 Multimedia Projector
Hdmi unsupported message - BenQ PE7700 Multimedia Projector
The HDMI signal says "unsupport" What does that mean?
Normally this is a problem with the HDMI cable. It is sending a garbled signal for some reason (could be a bad end connector or a broken wire in the cable) and the TV does not recognize it. The simple way to fix this is by replacing the HDMI cable. Answered from experience as I had this happen about a month ago.
HDMI signal says unsupport Google Search
Jan 01, 2017 | Televison & Video
Fire tv stick unsupport
well there's your first problem right there !! fire sticks plug into a USB port not a hdmi port if your tv doesn't have a USB port then its not for using with a firestick
Oct 20, 2016 | Televison & Video
Precision tv
If the TV accepts a USB connection try that format. If you have a HDMI port of the laptop, tether the two with an HDMI cable.
Other than that, unless you have WiFi capability between the laptop and TV receiver....nothing else works.
Dec 15, 2013 | Televison & Video
HDMI "unsupported" on konka tv
Xbox signals are not contactable with this Konka TV inputs.
Dec 19, 2012 | Televison & Video
All I get on my screen is a prompt saying "Unsupported Mode". Can't get it to display a picture.
Is this with HDMI only? Check for faulty HDMI cable and if it still has the message with a known good cable, your mainboard needs to be replaced.
Dec 10, 2010 | Apex Digital LD4088 LCD TV
Message of Unsupported video signal after attaching laptop to TV.
it sounds like the resolution the laptop is trying to send is not one of the resolutions that the television can display. TVs can display a range of resolutions, so try changing the laptop resolution, either increasing it (make the pixels smaller) or lower the resolution, try a variety of resolutions, one should work.
Jul 11, 2010 | Dell Latitude D420 Notebook
My xbox 360 elite has no picture, I'm using the HDMI cable and the message I get is unsupported signal - any clues please
there is a switch on the av cable that says tv or hdmi be sure the cabel is selected to hdmi. or try to check all that chanels that that an input in them
Dec 15, 2009 | Microsoft Xbox 360 Console
Keep getting unsupported mode message after hooking up xbox360 using hdmi cable. can anyone tell me how to fix this.
It is complaining because it cannot support the resolution thaat the xbox is feeding it, what is the TV maximum resolution it can display?
Dec 13, 2009 | Televison & Video
BenQ PE7700 Multimedia Projector Logo
75 people viewed this question
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Electro Med Services...
Tony
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
