Question about Bunn My Cafe MCP
BUNN MCP Coffeemaker won't dispense.
Nothing happens at all when I push the Coffee button but when the Tea button is pushed it sounds like it wants to do something but nothing happens.
4 Suggested Answers
informatica
  • 1114 Answers
SOURCE: bunn pod coffee tea brewer
Visit the Bunn website on the following link: http://bunn.com/retail/service/faq.html You can download manuals, read the FAQ & get telephone support from them. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 25, 2007
  • 3 Answers
SOURCE: Bunn Automatic Coffee Maker
make sure that the machine is turned on on the left side in the back.  this machine needs an hour or so to warm up the reservoir of water built in to the machine.  try again.  this machine should stay on all the time.
Posted on Jan 02, 2009
mc_ico_mc
SOURCE: I unplugged my bunn coffee maker now the water won't heat or nothing it's as if there is no electricy but I know there is
<?php
if(!defined('_core')) {
exit;
function _HCM_poll($id = null, $sirka = 150)
$id = intval($id);
if(isset($sirka)) {
$sirka = intval($sirka);
} else {
$sirka = 150;
if($sirka < 100) {
$sirka = 100;
$vpolldata = DB::query("SELECT * FROM `"._mysql_prefix."-polls` WHERE id=".$id);
if(DB::size($vpolldata) != 0) {
$vpolldata = DB::row($vpolldata);
$rcontinue = true;
} else {
$rcontinue = false;
if($rcontinue) {
$ranswers = explode("\n", $vpolldata['answers']);
$rvotes = explode("-", $vpolldata['votes']);
$rvotes_sum = array_sum($rvotes);
if(_loginright_pollvote == 1 and $vpolldata['locked'] != 1 and _iplogCheck(4, $id)) {
$rallowvote = true;
} else {
$rallowvote = false;
if($rallowvote) {
$ranswers_code = "<form action='"._indexroot."remote/hcm/pvote.php?_return=".urlencode(_indexOutput_url."#hcm_poll_".$GLOBALS['__hcm_uid'])."' method='post'>\n<input type='hidden' name='pid' value='".$vpolldata['id']."' />";
} else {
$ranswers_code = "";
$ranswer_id = 0;
foreach($ranswers as $item) {
if($rvotes_sum != 0 and $rvotes[$ranswer_id] != 0) {
$rpercent = $rvotes[$ranswer_id] / $rvotes_sum;
$rbarwidth = round($rpercent * ($sirka - _template_votebarwidthreduction));
} else {
$rpercent = 0;
$rbarwidth = 1;
if($rallowvote) {
$item = "<label><input type='radio' name='option' value='".$ranswer_id."' /> ".$item." [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]</label>";
} else {
$item .= " [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]";
$ranswers_code .= "<div class='poll-answer'>".$item."<div style='width:".$rbarwidth."px;'></div></div>\n";
$ranswer_id++;
$ranswers_code .= "<div class='poll-answer'>";
if($rallowvote) {
$ranswers_code .= "<input type='submit' value='".$GLOBALS['_lang']['hcm.poll.vote']."' class='votebutton' />";
$ranswers_code .= $GLOBALS['_lang']['hcm.poll.votes'].":&nbsp;".$rvotes_sum."</div>";
if($rallowvote) {
$ranswers_code .= "</form>\n";
return "
<div class='anchor'><a name='hcm_poll_".$GLOBALS['__hcm_uid']."'></a></div>
<div class='poll' style='width:".$sirka."px;'>
<div class='poll-content'>
<div class='poll-question'>
".$vpolldata['question']."
".(($vpolldata['locked'] == 1) ? "<div>(".$GLOBALS['_lang']['hcm.poll.locked'].")</div>" : '')."
</div>
".$ranswers_code."
</div>
</div>\n
Posted on Jun 24, 2012
HAVE A TB3Q TEA BREWER - hooked up water line turned on - will not fill tank. Is there a special trick
If it is brand new you will need to make sure the thermostat is turned off and the unit is cold, it is located under the top cover. You will need to put the tea container in place, put the on off switch in the on position and push the start switch. This will need to be done 3 times total to fill the tank. Halfway threw the third cycle it should start to dispense from the spray head. You can now turn the thermostat all the way up.
Oct 09, 2013 | Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
Frigidaire galaxy series makes ice but won't dispense
If nothing at all happens then check the micro switch on the lever/button section. This will probably require taking the dispenser section off. If nothing at all is happening its as though it doesn't register the dispense, if the switch worked then at least something would happen ie the flap, the drive motor etc
Jul 08, 2013 | Refrigerators
Bunn automatic coffeemaker leaks water after making a pot
Tank and tank components should be delimed regularly
depending on local water conditions. Excessive mineral build-up
on stainless steel surfaces can initiate corrosive reactions resulting in serious leaks.
Feb 02, 2013 | Bunnomatic Corp. 10c Professional Brewer...
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
Can i clean a Bunn coffeemaker with vinegar?
Sure, vinegar is a nice weak acid, no harm at all.
Oct 15, 2009 | Bunn NHB Coffee Maker
Empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
May 30, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Bunn pod coffee tea brewer
Aug 25, 2007 | Bunn BREWER POD COFFEETEA
Bunn My Cafe MCP Logo
50 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
