Question about Garden
My John Deere 318 shuts down as soon as I move shift lever, and the battery light stays on.
I removed the seat body of the tractor so I could get to the seat safety switch and wiring, I even put a jumper wire across the switch wiri, but still the same results. Help!
  • Garden Master
  • 14,378 Answers
The switch is bad,take to John Deere and they will replace or go online and look.
Posted on Oct 30, 2012
miket756
  • 2702 Answers
SOURCE: engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
Posted on May 02, 2010
pic498
  • 32 Answers
SOURCE: 1987 john deere 750 compact tractor 4 wheel drive, wont start
percussive maintenance my friend. Try banging on the solenoid and starter with a hammer while in the start position. Also, if you have a voltmeter, you can see where voltage is getting to and that will help you as well.
Posted on Jun 13, 2009
  • 143 Answers
SOURCE: I have a John Deere 318. I was out mowing today
I think you have a safety switch problem. Check your grassbox switch or the cutting deck switch. Stephen.
Posted on Jul 11, 2009
mickey813
  • 472 Answers
SOURCE: Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Posted on Oct 14, 2009
  • 51 Answers
SOURCE: John Deere lt 133 wiring diagram
Hope this page will help
http://www.google.ca/search?ix=sea&sourceid=chrome&ie=UTF-8&q=John+Deere+lt+133+wiring+diagram
Posted on Apr 07, 2012
John Deere 318. Why won't shifter move from neutral?
the dash is notched were the neutral posisition is , this notch (shift lever needs moved out of notch) is there for two reasons , the one you need to be concerned about is the clutch disconnect , this makes it impossible to shift into any direction without clutch pedal down , sometimes this lever will become bent and not press far enough for release arm of shift lever to allow its movement
love these little tractors , they got all the features of a bigger machine but with the size ease of a compact machine , for a small farm or big home garden there's nothing this machine cant do with the right attachments on it I sure wish JD still made em !
Sep 15, 2015 | John Deere Garden
1983 john deere 420 garden tractor thats stalling out when barely moving the hydrostactic lever or trying to engage the front or rear PTO
There are 2 safety switches on that unit as well. Most of them are right below the steering column in the firewall area. Search that to see if that unit has them. I'd be willing to bet one of them is faulty. Most are just a push button type.
Oct 18, 2017 | John Deere 420,1020,2010,2020,2510,2520...
I cleaned my carb on onan 318 john deere , now the needle and seat is not shutting off the gas . what is the proper float level adjustment
On most float-type carburetors, the float is usually perpendicular to the edge of the carburetor body when the needle is seated.Turn the carb upside down and adjust the float if necessary, to where the float is parallel to the carburetor bowl mounting surface. There are tangs at the front of the float where it hangs on the pin that can be bent up or down to accomplish this.
Jun 18, 2011 | John Deere Garden
John deer 6400 Shuttle shift will not engauge . I can here a relay activat in the fuse panel. If I hold the lever up the tractor will move forward and the same for reverse. But the lever will not stay...
You have the old style reverser which has been replaced by one that beeps instead of kicking out.These are a known problem with Deere and that is why you can't buy them anymore.The fact that you can hold it in yourself indicates that the enable solenoid and the forward and reverse solenoid are ok and all safety switches are working.You need to replace the reversrer.
Feb 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
Garden Logo
215 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
