Question about Onkyo TX-SR604 Receiver
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
Starts with snow which slowly over several minutes clears to a full screen. It now takes 10-15 minutes to fully display. TV shows perfectly when connected directly to a DVD player or to the cable box.
    Top Expert:
  • Onkyo Master
  • 14,553 Answers
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
Posted on Oct 30, 2012
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
  • 17 Answers
SOURCE: ONKYO TX-SR606 Single output to TV
Hi there. for your receiver, the only time it can upconvert is when you go out as HDMI. In your current hookup (component out to tv) the signal from your cable (using a composite) will not be able to pass through the component cable. This means you either have to hook up your cable box using a component cable as well or add a composite cable (yellow) from monitor out of the receiver to the tv. Page 22 of the manual will show a diagram of the video signal flow. hope this helps.. ^_^
Posted on Dec 03, 2008
ripleymojica
  • 643 Answers
SOURCE: onkyo tx-sr604
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Posted on Jul 02, 2009
  • 1015 Answers
SOURCE: No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Posted on Oct 03, 2009
SOURCE: Onkyo SR606 video upconversion problem.
Pressed and held cable/sat button on front of unit until "Attenuate" came up. Changed setting from 0 to 2
Posted on Oct 20, 2009
Testimonial: "Found this answer hidden in the Owners manual."
Cant get new HDMI board for Onkyo TX-SR604
It's usually the hdmi switching IC that goes bad on these. Not something you can really replace without the right equipment and knowledge.
Jul 10, 2013 | Onkyo Tx-sr604 7.1 Channel A/v Receiver...
I have a Onkyo TX-SR604 Receiver. I get no sound
Hello Fixya customer,
Thank you for your question.
A point to keep in mind here is that Zone II will only feed through an analog source. Since the Video 1 input is using the digital (coax, optical) input that that is your most likely issue.
Thank you for using Fixya, and please let me know if I can firther assist.
May 01, 2010 | Onkyo Audio Players & Recorders
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
Jul 02, 2009 | Onkyo TX-SR605 Receiver
I have surround sound, with aTX-Sr604 Amplifier. How doI adjust the sound?
http://www.devicemanuals.com/guide/AV%20Receiver/Onkyo/Onkyo-TX-SR604-Owner's-Manual-English-TmpnNU56RT.html
Jun 22, 2008 | Onkyo Audio Players & Recorders
No sound
Onkyo is a piece of shit! I had the same f'n problem....
Junk...............
Dec 16, 2007 | Onkyo TX-SR604 Receiver
My Onkyo 7.1-Channel Receiver
Take out all the cables unplug from mains for an hour ,plug it back in with no cables connected ,turn volume to full if it turns off its faulty ,if it stays on turn volume to minimum,unplug from mains,connect all cables,turn back on.
Sep 23, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604
This is not a problem with the onkyo
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR604 Receiver Logo
173 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
