Question about Gateway DX4200-09 PC Desktop
My computer locks up randomly - Gateway DX4200-09 PC Desktop
  • Gateway Master
  • 27,725 Answers
What sort of a lock up are you referring to ? does it hang or shutdown
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start.
scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
if you see something running that you does not need to be running select end now then you might you might uninstall that particular program
and some unnecessary programs
you should also check leads from motherboard to hard drive for secure dust free connections
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now
click start tick in both boxes this will schedule to on restart
do not have any input while chkdsk utility is in progress any might damage your computer
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
then defragment your hard drive
adding more ram is the best way of speeding up a computer
If youre not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules
you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible
you might have to many programs running at the same time putting to much strain on the CPU central processing unit
try uninstalling a few unnecessary programs
This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have.
Delete the files using Disk Cleanup
If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup.
It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need.
Open Disk Cleanup by clicking start all programs accessories system tools and then clicking Disk Cleanup.
In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK.
Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete.
When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation.
Disk Cleanup proceeds to remove all unnecessary files from your computer.
Watch the demo (1:00)
this should speed up your computer
hope this helps
Posted on Oct 30, 2012
2006 Pontiac g6 door locks gone crazy, locking and unlocking randomly.
I would take a close look at the connections in the power distribution box , also look at the door switches. most likely will find a loose connection coming into the power distribution box.
Oct 18, 2015 | 2006 Pontiac G6
Switch doesn't work. Why do door locks operate at random?
normally vehicle door locks operates thru the side door of the driver. it has the main control for door locks and it should work normally but not randomly.
Sep 05, 2015 | Cars & Trucks
Door locks cycle on/off randomly
Check your negative terminal on battery , for corrosion !
Jun 16, 2014 | 1993 Ford Taurus
H61m-ds2 motherboard wont stay connected to internet
If you computer lock up, because your motherboard does not getting enough power ? or your memory is bad ?
Aug 29, 2012 | Intel Computers & Internet
Focus 2 from 2005 The central locking randomly lock or/and unlock
makesure fuse fore central locking is not loose or just coroded fit new one
Mar 17, 2010 | 2005 Ford Focus
Flashers flash after replacing new battery, locks
Suggest that you reset the car's computer... by removing the ground lead from the battery and waiting for 3-4 minutes.
Reattach it and it should clear the problems...
Please let us know! -Jim
Oct 22, 2009 | 1997 Mazda 626
Randomly stops spinning and locks up , brand new drive, installed as per instructions. worked fine for a day, now randomly stops spinning and locks up computer during use. have scanned it, defragged it all...
If all software tests check normal but the hdd locks up then you may have gotten a bad hdd. Contact the warranty department of the hdd manufacturer to arrange an RMA and replacement. They should provide you a new drive free and will give you instructions on what to do with the bad drive. Hope this helps.
Jul 19, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Similar problem and I need to find a free wiring diagram
Change body computer (buy a used one).
Get it programmed by dealer because radio will be locked out.
Jul 16, 2009 | 2001 Cadillac Catera
Ipod mini -starts randomly with lock button on
check the alarm clock feature in Extras-Clock-Alarm Clock and make sure it's not set to on.
Sep 01, 2008 | Apple iPod mini M9160LL/A MP3 Player
Locked
find button with lock emblem underneath hold in for 3-5 sec should release control panel lock may be no good reason but they have been known to lock because they want too remember your dealing with a computer any random signal may cause this if all elese unplug for 20-30 min and retry
May 19, 2008 | Whirlpool GHW9100L Front Load Washer
Gateway DX4200-09 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
