Question about Maytag Dryers
Don't spin
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Model number?
Posted on Oct 30, 2012
Washing machine don't makes the spin dryer at the end of washing cycle
This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Feb 21, 2013 | Bosch Washing Machines
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
I cannot start. Has been acting up and missing somewhat lately but after sitting for 7/8 days it just spins. No attempt to start.
Check Fuel Pressure -- at the schrader valve on engine
fuel rail -- with a gauge 38 to 42 lbs approx
Listen by the fuel tank-- for the pump to come on,have someone
cycle the key on & off
Checking Spark will be a challenge if you have individual coils
Checking the Crank Sensor also an issue checking
Do not throw parts at it
Check for codes if you have a MIL Lamp lite on dash
Acting up lately & possibly missing ,troubles me, because
that is unacceptable with my vehicles. I don't go an hour
& I get a start on those type issues, unless it is raining or
lots of snow coming down
I don't see the no start connected to other issues, unless
you have an ignition module vs: cop coils & it is dead
Sep 13, 2012 | 1999 Ford F150 Regular Cab
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
RAZOR 500 BATTERY CHARGE MOTOR DON'T START OR EVEN CLICK DON'T WANT TO SPEND LOTS OF MONEY HOW CAN I CHECK THE MOTOR
Get a automotive battery charger that has 10 amps and hook it up to the motor. If the motor spins the motor is good. Just had to do this myself. Thought the motor was bad on ours and tested it found out it was good. Good Luck!
Jun 03, 2012 | Razor MX500 Dirt Rocket
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Just replaced the belt & it spins until I put clothes in it?
It sounds like you didn't get the belt tight enough to handle the load of wet clothes. Suggest you use something to put more pressure on the belt while tightening the motor bolts. Although there is a recommended torque for the belt, most technicians don't measure when they replace a belt.
Jan 01, 2012 | Maytag Dryers
Wont recover states on screen clearing lines and then freezes
It's sound to me you need to Replace the Compressor. Check spin-on filter (press MENU button on the control board & then keep pressing up or down arrow key till appear "FILTER CAPACITY", then press ENTER key). If the filter already recover 68KG/150LBS refrigerant since last filter change. Then you have to replace spin-on filter immediately! Over filter weight is the main cause of compressor damage
But if you want to make sure yourself, please do the following: Press recover & fix a vacuum gauge on your machine Compressor suction port & monitor the gauge is going up to13"HG suction, if not then you need to replace the compressor.
I wish this will help you to solve the problem. If so, don't forget to vote for it. Good luck!
Apr 26, 2011 | Robinair Cool Tech 34700Z Recovery,...
The washer will wash and drain but wont spin
If its an LE error on a LG Front Load...DON'T buy a sensor, don't call a repairman...the fix is EASY:
Turn the drum by hand 4-5 times to resettle the load, move spin speed to highest, Quick Wask, Speed Wash and hit the button! You're good to go.
Apr 21, 2011 | Washing Machines
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
