Question about Toshiba MW24H63 24 inch TV
Toshiba MW24H63 24 inch TV-DVD-VCR - can't program
Have the original remote, when I click menu I get the menu but when I try to change the time neither the up/down button nor directly keying in the numbers changes the time. Is there an additional step I am missing?
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
I would either call Toshiba customer service or Google the model number for a "owner manual". Keep in mind none of these combo units are made by the company whose name is one them.
Posted on Oct 30, 2012
How do you change to hdmi video source
There are several ways to change your video input source for the E421VO. First: the lowest button on the side of the TV will cycle through the inputs. (The power button is the top button.) The original remote has the Input button to the left of the Zero button at the bottom left of the number area. With both just press the key multiple times to go through all of the inputs. Alternatively, press the Menu button and look for the Source sub-menu. Use the arrow keys to move to the chosen menu. (On the TV, the menu button is below the power button. On the remote, Menu is the button to the top right above the arrow keys.) If you are using a universal remote, you may need to find one that matches the Input or Menu functions for your TV. A different code may help if the remote has either button. Otherwise, you'll need a different remote.
The manual for the Vizio E421VO is available from Vizio's product site: http://www.vizio.com/e421vo.html . Click on the Support/Manuals tab. The direct link to the manual is http://www.vizio.com/documents/downloads/hdtv/E421VO/UM_E421VO.pdf . All of these options are shown in the manual.
I hope this helps.
Jan 17, 2016 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
How to unlock FTA?
Hello
you must have its original remote control to unlock the set. If you haven't its original remote handset with you, try to borrow it from any of your friends or relatives who owns the same model. After unloking it, you can use universal remote.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET
OK.
Jun 25, 2011 | RCA 20F512T 20" TV
My Apex tv at2402 is locked and i don't have remote control, what need to be done to get this fixed?
OK . . .
First, press the TV button at the top of the remote so the remote is operating the TV rather than the cable box. Then try these combinations - hold down both keys at the same time for 1-2 seconds before trying the next one.
ENTER and TV (on the top row)
ENTER and MENU
MENU and TV (on the top row)
If these don't work, try holding down the MUTE key and then press other buttons on the remote one at a time while still holding down MUTE. Do not use the number keys (0-9), the POWER key or any of the keys on the top row (DVD, AUX, etc) except for the TV key.
If this doesn't work, please post back with the model number of your AT and T remote and I should have some other suggestions. If it's not printed anywhere on the remote, the model number should be inside the battery compartment. If you remove the batteries, replace them quickly or you may lose any codes you have programmed into the remote.
I'll wait to hear back from you.
Anyone looking for assistance with unlocking this TV, with the original Apex remote, please click on this link for instructions:
http://www.fixya.com/support/t8361476-locked
Mar 02, 2011 | Apex Digital AT2402 24" TV
I locked up my set by mistake need to unlock it and adjust channel for directv I lost my remote use the front keys which caused initial problem tried to adjust volume hit channel key
Hello
Tounlock your TV you surely need its remote control. Try to get it from somewhere, from any one of your friends, who own the similar model of TV, or buy it from RCA. After getting it try the following. You can unlock it.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
Jan 10, 2011 | RCA TruFlat 27F520T 27" TV
How do you unlock the tv?
Hello
To unlock your RCA tv, do the following
  5. Hold down Eject key on the front of the tv and MENU button on the remote at the same time for atleast 4 seconds.
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds.
OK.
Dec 14, 2010 | RCA TruFlat 27F520T 27" TV
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
RCA 20F420T FPA lock
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
Jan 21, 2008 | RCA 20F420T 20" TV
My Tv says Keys locked
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
Nov 11, 2007 | LG 42PX5D 42 in. Plasma HDTV
Remote not connecting
If you still have the original remote for the DMR-E80H, you can switch it back to operate with "1 CHK REMOTE" codes by holding down the "Enter" button on the remote and then press the "1" key.
If you don't still have the original remote, you can try the same steps on your universal remote (assuming it also has an "enter" key that worked with your recorder) and it could work.
Oct 02, 2007 | Panasonic DMR-E80H DVD Recorder
Toshiba MW24H63 24 inch TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
