Question about Yamaha Audio Players & Recorders
My sound cuts out when in cable mode but not DVD mode.
  • Rbraun Nov 04, 2012
    From the cable box there is an HDMI cable running to the receiver.
  • SD Tech
    SD Tech Nov 05, 2012
    HDMI is well known for having and being the cause of audio issues.
    Top Expert:
  • Yamaha Master
  • 14,553 Answers
Not likely a audio problem in the set----how and where is the cable connected to the set? Is a box being used?
Posted on Oct 30, 2012
    An HDMI cable is running from the cable box to the receiver.
'MODE NOT SUPPORTED' message appears on my TV screen
i have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Jul 13, 2009 | Samsung Televison & Video
Cd dvd deck cuts out on radio mode! How do i fix
check the antenna cable. It might be touching something and grounding it out
Jun 18, 2009 | Car Audio & Video
5.1 Surround Sound Cutting Out
HI,
Yes you are right man, this problem occurs only with the cable problem, i can explain you, if there is a receiver problem means you won't get the sound its dam sure,
only if there is a cable problem you will get some noise or sound cut off with the speakers, so you please check the cables properly it will be alright.
Mar 26, 2009 | GE GTD120 System
Heads are cut off off
It sounds like you may have the zoom mode enabled on the TV source. A lot of HDTVs have settings for how different modes like 4:3 format source video is displayed such as Normal, Full, Wide, Zoom and Wide Zoom. Each signal input may have a different display mode and that is why DVDs look ok and TV does not. Not all TVs have that feature but most of the ones that I have dealt with do.
It may also be a screen centre adjustment in the cable box or satellite receiver.
I hope I was able to give you a viable solution.
Cheers
Jan 04, 2009 | RCA R52WH73 Projection Television
Unable to get home theater sound on cable tv mode
I had this problem on my own tv and it nearly drove me mad, in tv menu under sound submenu their is a setting called spdif mode, there are choices in this mode that can be made, My current tv has Auto, off and pcm. some tv's have more choices. Try playing with these settings and its possible you can get it to work with cable, your cable signal probably uses a different sound format to the blueray/dvd player. note if this works the sound might not work when you go back to blueray/dvd player so note the setting before you change it in case you need to go back to it when you change over viewing choices. good luck.
Aug 17, 2017 | Panasonic Home Theater System System
Sound cut-out
Most likely this unit goes into protect mode due to heat detection. Try to see if there is a pattern to when this behavior starts. Does a lower volume level allow the unit to run longer? Perhaps there is a problem internally that is allowing DC voltage to get to the output stage. This will cause excessive heat which can then cause the protection circuit to kick in. This unit may need to see a bench with some test gear to locate the exact problem. If you can, look for any pattern and update this.
Dan
May 13, 2008 | JVC RX-6042 Receiver
DVD/VCR connect to TV sound but no picture
I am sorry to say that this does not sound like a simple solution for your problem. It is hard to be sure without examining the situation but, If the video comes on breifly and, then goes away it sounds like something is heating up and, then opening up and, disrupting your video. It could be something in the stabilization. You will need to refer this problem to a qualified repair technician. If you want to keep the TV and, since it does work in TV mode I would suggest that if you want to use the RCA type jacks to connect a VCR/DVD or what have you that you get an RF modulator to connect thru the co-ax. This way you can connect your Cable/satelite to the co-ax connector and, your VCR/DVD player to the RCA on the Modulator. These are availible at radio shack and can also be found on ebay. I hope this helps at all. don359@verizon.net
Apr 06, 2008 | Symphonic WF20D4 TV
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Blank spots
Is this during a DVD? if so then your DVD may be scratched or your digital coax cable is a cheapo inferior quality cable.
Dec 01, 2007 | RCA RT2660R Receiver
No sound on dvd recording
S-video cable does not carry sound, you need to use audio cables as well (there should be an audio port near the S-video port on your camcorder)
Oct 05, 2007 | Computers & Internet
35 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
