Kv35v-35 picture blinks on and off every 2 to 5 sec
The channel is stuck on aux and picture blinkson and off rapidly
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The model is an older set----likely the master screen is turned a little low-------located inside the set either on board at end of picture tube or at the high voltage transformer----set monitors brightness level to picture tube---a little low and picture will blink on and off---age of the set etc.
Posted on Oct 30, 2012
4 Suggested Answers
  • 1694 Answers
SOURCE: Magnavox TV
Bad IC inside tuner = replace tuner..............................T.
Posted on Nov 18, 2007
SOURCE: my zenith tv is stuck on aux
Try pressing the input button on your remote
Posted on Apr 21, 2008
ghost4548
  • 776 Answers
SOURCE: the sound on channel 3 is snowy and on aux 2 there
Superhetrodynes (TVs) piggyback video and audio signals (called IF -- intermediate frequencies). There are various IC's (Integrated Circuits) which detect these frequencies and separate them (filter them) to separate amplifiers and processing circuits. The first STAGE of these filters/processors are in the tuner. The tuner appears to have developed an internal malfunction.
Posted on Jun 30, 2009
Furnace problems
On - OK
1 Blink - Ignition failure. Check Gas flow, gas pressure, gas valve, flame sensor.
2 Blinks - Closed pressure switch. Check pressure switch (stuck in closed position).
3 Blinks - Pressure switch - failre to close. Check venter, pressure switch, vent blockage.
4 Blinks - Open limit switch. Main limit or aux limit are open. (My comment - Means overheating in chamber. Often result of blocked intake air. Bad filter. In my case, plastic wrap had been sucked into the intake. )
6 Blinks - False flame sensed. Check sticking gas valve.
Rapid continuous blinking - Incorrect twinning, incorrect primary polarity. Reverse transformer secondary leads, reverse primary wires.
Closed pressure switch can be from dirty combustion vents, bad chamber pressure - like missing screws, maladjusted gas pressure, failing pressure switch, loose hoses, moisture in the hoses or fan blades The switch need to be closed to ge the unit to work
Jan 23, 2008 | Goodman GMS90703BXA Heater
Tip
Comcast Xfinity DVR motorola DCX3400 series want to skip forward 30 seconds?
If you are like me who used to have the satalite DVR you miss the skip forward function that some of the remotes have. With comcast or Xfinity remotes you can program them. Mine says Xfinity on the bottom and since I have no others to compare it to I cant say this will work on all remotes. Watch for the blinks as they will signify that everything is OK. If they dont give it a minute or two and then start over again pressing the buttons fully down. Since most of the button funtions are already taken, and at least on my NEW TV it didnt come with Picture In Picture funtion so these buttons are not being used by me. So lets use that last PIP minus button for this example. When you are done you can still reassign the Aux button back to say a DVD player or something, but only if it doesnt still work. This sequence just programs the remote PiP button.
Press the Aux button one time
Press and hold the Setup button until the Aux blinks 2 times
after it does enter these numbers 01376,
now the remote should blink 2 times again.
press and hold Setup again until 2 blinks
now press 994
and press the Aux button
Press the Setup one time and now enter the numbers 00173
Press the Cable button
Press the PIP Channel Minus at the bottom of the comcast remote and you will see the lights blink again at the top of the remote to signify 2 blinks that it is done.
on Mar 02, 2011 | Televison & Video
Hey I'm trying to program my Comcast remote to control a Vizio VHT510 sound bar sound system bought at Costco. Any ideas if there is a way do do this?
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Dec 14, 2010 | Vizio VX37L Television
I have a Vizio 210 soundbar and the remote control is junk! I want the code the woeks on my Comcast universal remote control.
Nov 14, 2010 | Vizio High Definition Sound Bar
My tv is stuck on channel 2
Our old tv is stuck on Channel 2 and will only change ot aux. Help!
May 16, 2010 | Televison & Video
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
