Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Have dead short in 6300. Have been unable to fine short. What is the chance it is the PTO relay module. I say that because the PTO stopped beforethe fuse blew.
  • John Deere Master
  • 14,338 Answers
One way to find out,
Posted on Oct 30, 2012
  • Howard Thomas Oct 31, 2012
    One way to find out? - Replace module?
  • Thomas Perkins
    Thomas Perkins Oct 31, 2012
    Yes sir.
Everything works fine until I engage the PTO for the mower deck. The battery discharge light comes on and eventually the battery goes dead.
The PTO clutch is an electro magnet. There is probably a dead short within the clutch body. Replace the Clutch.
Aug 26, 2015 | Cub Cadet Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
I have a john deere 737 ztrak with a 23hp kawasaki engine. It cranks fine and runs strong. However, when the pto is engaged and begin mowing, the engine stalls. Also, the battery charge light comes on...
First. My disclaimer. I do not have first hand experience with your model mower.
Well, it sounds like when you engage the PTO the power to the PTO shorts to ground causing a) your charge light to come on as the voltage drops substantially and b) your mower to stall as the minimum voltage of the ingnition system is reached (or some other effect is at work). The clutch is might be internally shorted, or you may have a frayed wire in the PTO circuit. You may or may not have a PTO relay. If you do, it is sure to burn up if you continue using your mower. If you do not have a relay, you will definitely burn out the PTO switch. It is odd you are not blowing an inline fuse if this is the correct answer. Check your PTO circuit with a continuity tester to tell you if there is a short (or measure resistance directly with a voltmeter on ohms).
Aug 09, 2011 | John Deere 23HP VTwin Dual Hydrostatic 54"...
Pto energizes clutch when no one is in the seat, when someone is in the seat with engine running the blades activate and the engine stopos right away. I have replaced the seat switch ,pto switch clutch...
Depending on the model I would suspect the PTO relay (model specific)is faulty. If its the new X series I would replace module under dash that is held in place by one 10mm bolt.
Jun 26, 2011 | John Deere 22HP VTwin 48" Riding Mower
Toro 265-6 model 72045 PTO clutch will not engage. PTO checked with 12V and works okay. Both relays checked and working okay. All fuses are good. Not sure how to check PTO switch. Any other suggestions on...
ohm out the clutch......should be 2-4 ohms any less means the clutch has an internal short and will need to be replaced. also check the saftey interlock module, however the modle numbers u gave do not come up, relays checked ok? how did u test them?
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
Pto stops working while mowing
is this by any chance a husqvarna or cub cadet/yardman? ran across this problem in all three. they use a cheaply made clutch that's prone to bearing failures. the clutch [not cheap, just cheaply made] needs to be replaced, the pto switch needs replaced AND the little relay under the dash - if you replace the clutch and switch and not the relay, it'll keep taking out the switch and that can get expensive in a hurry
Aug 24, 2009 | Garden
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
104 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
