Question about GE Profile WPRE6100G Top Load Washer
Clothes come out streaked or dirty - GE Profile WPRE6100G Top Load Washer
  • 673 Answers
Clean the inner walls of the drum. And also use fresh and clean water for washing.
Posted on Oct 30, 2012
My Kenmore Elite Top-Load Series 700 Washer leaves streaks on clothing. It looks like dusty powder. I use liquid HE detergent. It was a normal cycle of dark clothes, not heavily soiled or dirty. Also
THE stains on your clothing especially on whites are most likely due to a top seal failure on your transmission. transmission leaking oil. if the clothing affected or the stain can be removed with a solvent like gas, kerosene, paint thinner repair on washer will exed the value .... if the streaks or stains can be removed with a water soluble detergent then the stains are caused by the soap and or hard water deposits in your washer . then the solution to cut way down on soap usage in your washer and or running an acid wash (soap is alkaline acid will dissolve it . make sure not to over solvent your clothes and to rinse all solvents out completely . be careful !!!! a solvent soaked t-shirt bunched up and left in tightly sealed plastic bag WILL CATCH ON FIRE!!!!
Jan 22, 2015 | Kenmore Washing Machines
White clothes come out with random black streaks
Drum is dirty from main barring leaking. This is job to fix by professional
Sep 22, 2012 | Asko W6021 Front Load Washer
Copies come out with dark streaks
Looks like a dirty, scratched or contaminated drum. Try wiping the drum with a very soft cloth, the streaks should go away but may re-appear. If there are visible marks on the drum that cannot be wiped of with the cloth, the drum will have to be replaced. DO NOT TRY USING ANY SOLVENTS TO CLEAN THE DRUM.
Jan 25, 2011 | Canon imageCLASS D660 All-In-One Laser...
How can I cure streaking on the reverse of the paper? Epson S20.
streaking on the reverse side suggest dirty rollers.
1. remove cartridges form the printer
2. disconnect all cables
3. check full paper path for presence of debris, lint, bits of paper, remove if necessary (you can put printer on it's back or sides for esy removal)
4. mount on long skewers lint free clothing or tissue
5. wet tissue/cloth in isopropyl alcohol and whipe all rubber rollers on paper path till no discoloration to the tissue
6. connect all cables
7. insert inks and print test page
if necessary, you need to clean rollers again, but once is usually sufficient. to keep printer in good condition, you need to print at least one page per week and periodicaly clean the rollers, that depend on amount of printing done.
Jul 28, 2010 | Epson Printer
I used a soap/water solution to clean my plasma screen but used a regular cloth instead of microfiber and now there are horrible streaks on the tv that won't go away. Help! Is there anything I can do?
You can try to use a harsher cleaner like lysol but sometimes the streaks are permanent. The screen is glass but some tvs have a glare reduction layer that can be destroyed with harsh cleaners (like lysol). Your soap cleaning shouldn't have damaged it.. I would try just water and see if the streaks change. If they keep changing as you clean, its probably some scummy residue, but if they apprear to be permanent, then it could be damage. I always recommend the store bought plasma cleaner with the microfiber cloth, but if you smoke or have a really dirty tv, sometimes you have to cut it with lysol or something. Clean at your own risk, as anything not made to clean the tv can sometimes cause damage. I've seen paper towels scratch the glossy frames sometimes even.. good luck
Jun 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
We have a Frigidaire Gallery 16 cycle Front loading clothes washer purchased in 2002 and it is leaving what looks like grease streaks and stains on some clothes. We have washed only with Cold water. any...
I removed the drawer for detergent and bleach dispensing and it was
quite dirty form build up of dirt and detergent.
than ran hot water cycles and it seemed to fix.
Oct 14, 2009 | Frigidaire Washing Machines
Streaky, filmy black stove top
Re: Streaks
After a final clean up with a a wet & well rinsed cloth buff the surface with a microfibre cloth & it will look like new.
If there re any difficult ares to remove use a glass cooktop
paste cleaner (from Sears, etc)then and finish off with the microfibre cloth.
May 25, 2009 | Cooktops
Dirty Mirror
You must be very careful when cleaning the mirror, it is not like any other mirror as the silver is on the front of the glass. I believe that Hitachi's are made of glass and not mylar.
Do not use a glass cleaner, as they have drying agents in them.
I try to avoid cleaning the mirror unless it is really dirty. It is very easy to leave streaks on the surface.
Most likely you would be well served by using a mild detergent in a bowl of water, a soft cloth, (I like to use cloth baby diapers) anything that is lint free. Do not let the cloth drip into the set.
Clean the surface with the damp cloth and dry with a clean dry cloth.
Try to use the dry cloth to remove any streaks.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a FixYa rating. If not then please comment to this post and I will try to help you further.
Thank you for you support and use of FixYa
May 14, 2009 | Hitachi 60FX20B 60" Rear Projection...
My printer- Brother HL1250- is making grey streaks on the paper
More than likely the grey streaks are from dirty fuser rollers open the fuser area and insect the fuser rollers i think they should be grey take silicone lubricant and wiat ntil rollers cool down and clean with a coton cloth do not scrape with anything sharp if this does not work then you ned to remove the glass platen and clean the optics( mirror and lens with tissue and glass cleaner wen machine is not hot also insect expsoure lamp( do not touh lamps because the oil from your hands will cause the lamp to get extremly hot and burn out good luck
One other thought is there could be marks from the stripper fingers at the fuser section look for build up of toner on them if so clean with q tip and alcohol
Dec 04, 2008 | Brother HL 1440 Laser Printer
Fisher Paykel washer GWL15
I have noticed this same problem and wonder if it because my FP washer wasn't draining properly and dirty water couldn't get out. See my post on "eco smart won't drain, smells hot". I found one of my husband's socks when I removed the black motor/white plastic housing on bottom of washer. tip washer back and you'll see this electric motor. My post tells how to remove it. then you can look into that small space and see if there is something plugging it.
I am waiting on my replacemt motor, and hoping all the dirty streaks are gone. the water I drained out after i removed the sock was really grimy and gritty with dirt. I'm sure the sock has been holding a lot of junk in the bottom of the tub and it would end up on clothes during spin cycle. My issue has been going on for a few weeks and then the motor finally smoked which led to the sock discovery!
Oct 02, 2008 | Fisher Paykel EcoSmart GWL15
GE Profile WPRE6100G Top Load Washer Logo
29 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
