Question about Panasonic TC L42E50 - 42" VIERA E50 Series LED-backlit L - TC-L42E50
Panasonic viera wont turn on after power surge
After a power surge last week, the tv totally shut down. After turning a variety of boxes on and off, the tv worked again. Now, the tv has shut down again..... no power.
  • Betsy Why Oct 30, 2012
    Zero lights..... The power strip and all the AT&T stuff works.
My panasonic 42 inch does this if the power goes out or tv is unplugged prior to powering the tv off first. I unplug the power from the wall wait 2-4 days max then when I plug it back in the tv comes right back on with no problems. Don't know why I have to wait so long to plug it back in
Posted on Dec 14, 2013
    Top Expert:
  • Panasonic Master
  • 74,136 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 01, 2015
  • Panasonic Master
  • 670 Answers
In Panasonic TVs in such cases a few components like fuse, rectifier, main dc filter, and some transistors/STRs go bad. Replace them and the set is up again.
  • Panasonic Master
  • 8,617 Answers
Does the power indicator blink when you try to power it on? If so let me know the number of blinks. If the power light doesnt do anything let me know that as well and I will assist with the issue.
Posted on Oct 30, 2012
  • Jacob Budreau
    Jacob Budreau Apr 11, 2014
    mine does this as well. the power light doesn't do anything
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
skotkolr
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
SOURCE: my panasonic viera wont turn
We had this problem. Very common to Panasonic. The problem is your A board. Panasonic is cheap because they spec'd a board that was possiblly defective. As long as you purchased within 1 year, you should be covered by manufacturer's warranty and Panasonic will send someone to your home to repair. Otherwise, if you don't have extended warranty you will have to pay.
Posted on Nov 28, 2010
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
djchillsnyc
  • 151 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
My Panasonic viera wont turn on from standby. It has a solid red light, no flashing
Hi Cloda,
It is mostly the power supply section which gets damaged due to power surge. In many cases the damage is repairable. Please contact some local TV tech.
Good Luck.
Jan 13, 2016 | Panasonic VIERA Televison & Video
Panasonic Viera plasma suddenly shut off and wont turn back on and when off it has a dark line on screen
Try disconnecting all HDMI cables and plugging the TV into a new wall outlet. If the issue is resolved, it may have been caused by a small power surge from either your wall outlet or one of your source devices.
Nov 13, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
After power cut panasonic viera flat screen tv wont turn on
check fuse on meter board isnt blown.or easir plug another applience in the socket the tv is using. If it works then your tv is most likly damaged from a voltage surge, which can happen from power cuts.
Oct 15, 2013 | Panasonic VIERA Televison & Video
Panasonic Viera tc-p60st30 tv will not turn on. No red blinking light. Relay clicks every 10 seconds.
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 14, 2013 | Panasonic Viera Plasma TV TC-P60ST30
Panasonic viera will not turn on
Try the following troubleshooting steps.Check power cord and power outlet, possible light switch problem.
Check if you TV savy check the P board if the P board is not good check the fuses on the P board.
If the P board is OK check the A board.
To check these Unplug the TV , Disconect A5 A6 and A7 on the A board and plug the TV in and see if you get a white screen if this is the case your P board should be OK.
Nov 20, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
My volume just shut down on me. how do I turn it
go into menu of tv make sure speakers are turned on--if you are using a cable box turn the cable box volume up-let me know if this helps you-djstvrepair@comcast.net
Sep 04, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TC L42E50 - 42" VIERA E50 Series LED-backlit L - TC-L42E50 Logo
1,114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
