Question about Berkeley Forge G-PH001PSS Open Flame Patio Heater
How to light the pilot
Manually
How to light the Bosch TF250 pilot light
I believe this is a hydro-sparker pilot ignition then burner on when T-Couple/Flame Sensor acknowledges pilot lit.
W/O the signal feedback the Gas Valve will not open and light burner.
This is a Technician Service Job as you have insufficient knowledge to DIY this potentially dangerous LP/NG Control Valve/Sparker Assembly
I assume that lack of knowledge by your lack of a Manual for the Unit
You cannot force ignition on a hydro-sparker manually.
Sep 08, 2014 | Bosch Water Heaters
Need to purge air from gas line for water heater
It could be that the gap for the igniter is too big Try lighting it manually There should not be that much air in the line .
Jun 14, 2017 | Rheem Water Heaters
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
Potterton profile 60e pilot light
the e stands for electronic there is no manual pilot light
Jun 15, 2012 | Kitchen Ranges
Magic Chef range the pilot on the oven will not light.
Is this a manual lighting pilot,do you light it?
If so you may have a bad gas valve.
If this is an auto light pilot it could be the electronic spark is bad.Im guessing the popping noise is the autospark trying to light.
Jan 05, 2010 | Magic Chef Ovens
Radiant Flame Heater by DESA International pilot light will not stay lit. The manual is not available. Could this be a thermocouple? If so, how do I change it. The flame in the "logs" will light...
You need to replace the pilot light. This is an easy replacement, it goes from your gas control valve to its place in the heater. You can try "taping" the dust out or pulling it out and blowing it clear. This will fix your pilot light problem.
Sep 29, 2009 | Heating & Cooling
How to light a American Standard furnace
If it is an old furnace with a manual pilot light there are pilot lighting instructions usually on a door or panel. If it is 15 years old or newer it probably has either a spark ignition or a hot surface ignitor. These can't be lit manually. If they fail they usually require parts to be repaired.
Jan 01, 2009 | Heating & Cooling
My pilot light on the water heater won't stay lit
The thermocouple or gas valve needs to be replaced. Start with the thermocouple.
Good Luck
Dec 09, 2008 | Water Heaters
Heating & Cooling Logo
Top Berkeley Forge Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Berkeley Forge Heating and Cooling Expert? Answer questions, earn points and help others
