Question about Dryers
I have a Maytag dryer, trying to service it, I can't find where the model number is. Front loader electric. I've looked everywhere front back and side.
  • 3,463 Answers
Open the door, and you should find the details on a label on the flange on the inside of the door opening
Plz rate my solution.
Thanks.
Posted on Jan 03, 2009
My maytag model;HYE2460AYW has bright orange glow what is that from how do i fix it is electric front loader
I'm assuming it's a gas dryer. The glow is the ignitor for the flame. It will glow the whole time the dryer is on. This is normal.
Aug 27, 2014 | Maytag Dryers
Maytag Centennial 7 Cu. Ft. Electric Dryer, how to remove front
unplug it,remove the top panel screws in the back,remove the control panel and then you can remove the front.go here
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDG9700AWW/3048/0151200/M0702017/00001?
blt=06&prst=&shdMod=
you'll see number 14 and 15,you have to remove the 4 1/4 inch screws on the top and the two phillips screws that are behind the door.
Oct 13, 2013 | Maytag Neptune MDG9700A Gas Dryer
We've got a noisy Maytag gas dryer and it has been suggested it needs brake shoes on the front and rollers on the back of the drum. Is anyone near enough to Oberon to assist us please?
To access the front you remove 2 screws at the base of the front and remove the front panel, newer models you pop the top first. Not all maytags are exactly the same. The front of the drum rides on plastic glides and the rear of the dryer rides on rollers. I made a few maytag dryer home videos HERE
Jul 23, 2012 | Maytag Dryers
Dryer will not run but there is power to the unit
Number 11 is my primary suspect. Look for lint in the ductwork. Air restrictions can cause this puppy to melt when temps exceed 300f. To access the innards you remove the door first and then the goalpost front. That exposes the hooks which hold down the top. Once you get them out the way you remove the front shroud and then the drum. Give it a good clean and check all components for continuity.
Maytag sloped front service manual
Oct 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i access the back of a Model #MDE8600AYW - MAYTAG Dryer. i think i need to replace the drum rollers but dont think i can from the front panel.
yes it can be accessed from the front panel as it is located on the back right inside of the dryer.
1) unplug dryer
2) open door remove screws
3) with a flat tip screw driver pry gently up on the top corners it will pop
4) move front panel forward and disconnect door switch
5) sit panel aside
6) lift top lid of dryer 90 degrees it has clip/hinged on back
7) look to the right back of dryer, it looks like a spring in a metal box disconnect and replace.
Hope this helps Tim
Sep 25, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
My dryer will not heat up. What can I try at home before calling a repair person? It is a glass door dryer that matches the Maytag front-loader washer.
pull the vent hose off and turn the dryer on and see if there is hot air coming out, if not then it is the heating coil
Aug 12, 2010 | Maytag EPICz Electric Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is a front loader approx year 2000 maytag. dryer wont turn on. already tried flipping breakers
Check the wiring in the back to see if any wires are burned off. There is also a thermal fuse under the top that may be bad. You can check it and see if it is bad. I bet, however, the problem is in the wiring. The plug that goes into the wall may have a wire that is burned off as well.
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Leak samsung front load washer
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
learn more detailed information about the recall by visiting Whirlpool...or Samsung's at www.samsung.com/washerrecall.
Hope you find useful!
Regards Faggly
Mar 19, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
