Question about Mitsubishi WS-65907 65" Rear Projection Television
I have a WS-65907 tv, it wont turn on
I have a WS-65907 tv, when i push the power button it acts as if it turns on but then you can hear it turn off and theres no picture or sound for the few seconds it trys to start up
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Posted on Oct 30, 2012
  • 5 more comments
  • Damion
    Damion Oct 31, 2012
    at first i got 1-2 then i powered on it did its thing then i redid it and got 2-2
  • Damion
    Damion Oct 31, 2012
    I checked the fuse right by the power cord inside the tv and it's still good
  • SD Tech
    SD Tech Oct 31, 2012
    2,2 means one of the green pico fuses on middle board is bad because of short in convergence circuit==I have instructions for this based on actual model number ---parts cost under 30 dollars let me know and we will find a way to get them to you for free.
  • Damion
    Damion Oct 31, 2012
    we decided to have the mitsubishi authorized service center fix it, I'll save this page for if this happens again for future refence thanks anyway though
  • davidctyson
    davidctyson Nov 27, 2012
    I have the same issue and have the 2-2 error. It's not worth the money to have somebody fix but if I can do myself for cheap I would be willing to try. How would I go about getting the parts and instructions to fix
  • Adrian Hohenwarter Jan 03, 2013
    I have the same TV. Won't turn on. Only tries to turn on and clicks off..no pic. I did diagnostic and I have the 1/2 blink or no error. What does that mean then? Adrian
    What if it shows 1/ 2 and 'no error' but still turns off immediately with no pic.
SOURCE: TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
Posted on May 08, 2007
  • 297 Answers
SOURCE: mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Posted on Jun 19, 2008
  • 1894 Answers
SOURCE: mitsubishi ws 65907
do u hear a clicking sound.
this can be due to relays getting tripped
Posted on Jun 22, 2008
  • 1894 Answers
SOURCE: mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
SOURCE: mitsubishi ws-65907 tv not turning on
Let's just buy new TV's to help stimulate the economy.........
Posted on Feb 22, 2009
Won't turn on
These sets have a short protects that will shut down the tv if certain things are wrong. A good start would be to extract a code and see what is shutting the set down. To do this you simply hold down the menu and device (or input) buttons on the front of the tv and read the sequence of blinks. There are 2 digits seperated by pauses. 2.2 is common and points to a convergence failure. 2.3 points to the power supply. I can provide more codes if either of these are not the code for your tv.
Jul 05, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws 65907
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv will not power on
one of the two pico fuses that protect the convergence chips this model uses is gone--see attached photo--
NEVER change just the fuses---if one of the two fuses is blown--the convergence chips got them-----
there are several ways to proceed from here-check the two fuses indicated in the photo and tell me if either or both are bad.
SD TECH
Jan 03, 2010 | Mitsubishi WS-65907 65" Rear Projection...
My Mitsubishi WS-65907 turns off immediately after you turn it on
Perform the self check that this set should have: when you turn it on and the power light goes off:
On the front of the set press and hold both the MENU and INPUT (OR DEVICE) BUTTONS AT THE SAME TIME FOR AT LEAST 5 SECONDS----then release both buttons.
The power light should blink a two digit error code--for example----------2 blinks, a pause and 2 blinks--this is the most common one and the easy one to know what is wrong.
Let me know what you find and I will tell you what it means.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 15, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Turn it on and turns off again
sounds like your powersupply is bad. usually reasonable repair. 150-250 parts and labor
Jun 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907 tv not turning on
Dec 14, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
Mitsubishi rear projection tv model ws-65907
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
TV wont stay on
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
318 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
