Question about Vitamix Super 5000 Work Top Blender
Leaking blender jar - Vitamix Super 5000 Work Top Blender
  • Vitamix Master
  • 1,309 Answers
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Posted on Dec 05, 2013
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
My blender leaks at the base of the carafe
A couple of things you can check.
Unscrew the glass jar from the bottom.
Check to see if the grey seal is between the metal blade assembly and the glass jar. I had this issue and it turned out to be that a friend had reassembled the blender jar parts after taking it apart to clean it.
Mar 07, 2014 | Oster 6700 Work Top Blender
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
Leaks from the bottom of the glass jar. Bought a new gasket and it is worse than ever.
Are you sure you are installing the gasket correctly?
Leaks are usually the result of a misaligned or cross-threaded blender jar base or from the gasket being installed incorrectly. Make sure the gasket is installed between the blade assembly and the screw on base.
If this does not help, please reply or repost.
Dec 07, 2012 | KitchenAid 5-speed Blender With Glass...
Why does my blender leak?
hi,
sounds like the bearing assembly went, right where the motor connects to the blade, you can get a replacement base from them, have to find the model number and go to their website. doubt you burnt it up. cuisinarts supposedly are commercial quality.
jm
Jul 20, 2017 | Cuisinart SPB-7CH SmartPower 40-Ounce...
Blender jar is leaking
Make sure the seal is installed.
Apr 23, 2012 | Waring Pro SDM50 2-Speed Blender
My new 5 speed blender is leaking help
Check that you have the seal between the collar and glass jar. It looks like the one here. If it missing the jar will leak badly. If this is not missing, please describe where the leak is.
Dec 20, 2010 | KitchenAid KSB560 5 Speed Blender
My Cuisinart blender start leaking after a few months of use.
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
There is a leak in the caraffe(or jar). It is at
Common issue with all of these carafe's. Once the jar starts to leak the bearings are shot and it is time to replace the jar. The bearings are non-replacable. Bad design in my opinion. I was able to get my last jar (I have been through 3 before the 5 year warranty went out) to last by hand washing and not putting it in the dishwasher, but after 4 years of use on this jar it failed too.
Nov 29, 2009 | Blendtec Extra Carafe / Jar for the Total...
Vitamix Super 5000 Work Top Blender Logo
223 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
