Question about Olympus PEN EPL2 Digital Camera
Olympus PEN EPL2 flash won't latch
The popup flash on my Olympus PEN EPL2 will no longer latch in the down position so it is permanently popped up. It looks like there is a spring-loaded catch in the bottom of the body recess that is stuck in the down position. The spring-loaded release slider on the back of the body operates normally (but perhaps a bit looser than in the past) and the flash still functions. I can send it to Olympus for repair, but I'd be grateful if anyone knows a simple fix to get the catch working again to save me the trouble and expense.
  • 479 Answers
SOURCE: Olympus e510 shutter button locking up
reset the camera through the menu.... put the camera in P mode, menu, right over to card setup, down to custom reset, right arrow, ok, up arrow to yes, ok
Posted on Oct 15, 2008
rapanSF
  • 150 Answers
SOURCE: shutter stuck half open
Try to dismantle it and fix the shutter yourself before paying for repair.
Posted on Nov 06, 2008
  • 70 Answers
SOURCE: fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Posted on Apr 20, 2009
cammedic
  • 667 Answers
SOURCE: internal flash not working on olympus e500
The Xenon flash tube in modern strobes rarely 'burns out'. I would guess that a switch that is activated when the flash pops up is not working properly. More info can be found here: http://forums.steves-digicams.com/olympus-dslr/159660-e-500-built-flash-not-working.html
Posted on Dec 09, 2009
  • 4090 Answers
SOURCE: Olympus E-510 Flash & Auto-Focus Problems
Sounds like the main circuit board has got problems. If its under warranty use the manufacturer. But if not a camear store should be able to provide a quote. I admit that the repair will be about 150-180 because of the time involved in replacing the board and possibly the flash unit.
But quotes before bankruptcy..
Please rate my help++++Thanks for using FIXYA
Posted on Jun 03, 2010
Testimonial: "Hi Dennis ~ I know it's been 3+ long years since you last replied to my question about my camera's flash problem (hey, life happens - LOL)but I wanted to thank you for taking the time to answer me. I really appreciate it! I haven't taken it in to get fixed yet (mainly b/c of the $$$ issues) - but it still takes great outdoor pics, and it does take really good indoor pics - if there is a lot of natural light. Hopefully some day I'll be able to get it fixed - if I don't sell it first (for a discounted price, of course LOL) Thanks again, Dennis!"
Hood latch will not close.
if you look down into the latch with a flash light you should see the hood release cable. it will be attached to a lever. if the lever is stuck all the way to the drivers side than the latch is sticking. Spray some penetrating lube into the latch and then use a thin blade screwdriver to help push it the other way. Continue to spray lubricant, pull the hood release, and move the lever with a screwdriver until it moves freely.
I kjnow this video is a ford but the mechanism is the same
Jan 18, 2016 | 2005 Toyota Corolla
Epl2 black screen
I can't think of much. Perhaps you pressed the button, to change the view from monitor display, to extra view finder display?
Try pressing that again.
I don't thin it has anything to do with the brightness settings of the screen.
Jul 22, 2014 | Olympus PEN EPL2 Digital Camera
Does not flash
http://www.imaging-resource.com/PRODS/EPL1/EPL1FLASH.HTM
It may be switched off. There could also be a break in the wiring to the flash. Without more, there's no way to know.
The first step would be to verify that the flash has not been set to "off" in the flash mode.
Jul 14, 2013 | Olympus Cameras
Electrolux Dishwasher door won't close or latch shut
Contact a professional to replace the door switch or adjust it.
Aug 07, 2012 | Electrolux Dishwashers
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
2010 Town & Country trunk won't shut
When you pull the trunk handle back towards yourself to open the trunk, it may be sticking in that position, so give the handle a tap to pop it back into its original position. Then shut the trunk and see if it has latched.
Jun 30, 2012 | 2010 Chrysler Town and Country
My nikon D-80's flash won't pop up, yet it also won't go past the flash sync speed of 1/200 while flash is down
Was the camera impacted? Sound like the flash up switch if always closed. Remove battery. If you carefully remove the flash cover (two screw underneath) by first inserting a business card under the flash on the rewind side (yeah, we haven't come up with a better term!) at the back and slide it forward freeing the flash down latch), and do not touch the flash tube as there is 300 + volts across it if it is charged!
Look at the pivot for the flash on the release button side at the back, you will see a small switch. the top part may be under the activating rod - reset it above the rod and it will now work properly
Once again, be careful - there are 300 volts across the flash tube if it is charged
May 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
Doge Charger Year 2007-trunk won't latch in order to close it
Look at the latch on the trunk lid. Sometimes they close. Put your key in it and open it, as you do this take a screwdriver or pen and pull the latch open.
Jul 01, 2011 | Dodge Charger Cars & Trucks
The latch for the rear hatch got flipped to the lock position while the door was open. Now the hatch will not go down, latch or unlatch.
You need to take something like a pen or something round like that and put it in the latch and pull outwards while you use the door handle to 'open' it. Put the pen where the latch is curled together. If you need to look at one of the doors to see what it looks like open. Good luck!
May 11, 2011 | 2010 Toyota Venza
1998 Chevy Cavalier trunk release issue PLEASE HELP
when it locks around the pen and you pull up on the pen does it unlatch,wd-40 the latch,if it keeps popping up lube the cable thats attatched
Jul 07, 2008 | 1998 Chevrolet Cavalier
Olympus PEN EPL2 Digital Camera Logo
55 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
