Question about Garden
John deere auto steer wont .lost autosteer jd 9520 code came up ssu 43 canceled code turns on in display but not resume switch checked fuse
Autosteer isues
4 Suggested Answers
  • 3 Answers
SOURCE: blades will not ingage
your electric pto clutch switch is bad replace it
Posted on Nov 15, 2008
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
Ajust a John Deere steering clutch
Harvey, Check the attached links,instruction and guides, the last link is the 420 adjustment. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=68159
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=54625
Thread JD 450 Steering Problems
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=crawlers&th=40562
Apr 29, 2016 | John Deere Model 420 Tractor 1/16
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
Were are the 2 fuses on john deere LR 1335 auto mower.????
Where's your handbook. Go online to JD if you haven't got one.
Mar 30, 2015 | John Deere Garden
Error code 68 on a 3320 john deere
a code 68 0nthe dash display means the relay that supplies power to the engine controls has Not cycled correctly, most all the new stuff in the first two seconds of turning the key tests more stuff than a human could dream of , this is one of them , seems the computer turns on/off this relay so fast its looking for it to cycle ,before it turns it back on to start the engine , Jd calls it a "Hold In " relay , this problem is gonna require a Jd scan tool to figure out whats wrong , but do try and remove the relay and give it a few taps on your palm to see if anything s loose inside of it , silly as it sounds but relays do stick , but I feel this ones electrical
this fault should lock out the starter the book says
Feb 16, 2015 | John Deere Garden
4310 john Deere e hydro
Check to make sure the brake is completely return to the off position, all the way back, it cancels the cruize when depressed
Mar 12, 2014 | John Deere Garden
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
JD L111 tractor, nothing when I turn the key, battery is charged and good, but nothing when I turn the key, no lights as well
The first thing you should check is the fuse which is under the hood somewhere near the steering column. If the fuse is good then It could be either the ignition switch.Or it may be the relay which is next to the fuse.You can probably have those tested at napa before you replace them
May 15, 2011 | John Deere Garden
JD 6310-several electrical problems- hydraulic pressure warning light flashes intermitantly with blue caution light, hazard light fuse keeps blowing, and the entire dash will sometimes go dead then...
I may be able to help.If you can tell me what codes the tractor has stored that would be a good place to start.You can get the codes by putting a fuse in the "cal" position of the front bottom half of the fuse box,then use the signal light switch right turn signal to get to each controller.When you get to the controller you want(bcu,hcu,rcu,bif) pull back on the signal light switch(flash to pass) and the signal right one more time.Next you need to momentarily turn on then off the hazard lights.Now record the codes in each of the controllers and send them to me and we will go from there.Let me know if you can,t get this to work.
Aug 18, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
