Question about Maax Soprano II: One-Piece Shower Module W/o Roof Cap but with One Seat & M
Maax pearl stopper plug removal - Maax Soprano II: One-Piece Shower Module W/o Roof Cap but with One Seat & M
Pearl Trillium diverter and hand held shower
The faucets on your Pearl tub do not come from Pearl. They were supplied by the local plumber who installed the tub.
Go to your local plumbing store and match up what you have.
Rod
US Parts Center
Jan 04, 2014 | Maax Pearl By TRILLIUMbla Pearl Trillium...
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Nov 05, 2013 | Maax Brio II One-Piece Neo-Angle Corner...
Bathtub drain plug
It should be easy. You should be able to unscrew the stopper and take it out. The part of the drain that sits inside the tub screws in to the drain under the tub. It takes a special tool to remove it but you can use either two screwdrivers or is the opening is big enough the handle of your pliers and put them in the drain. If you look inside the drain there are two or three braces that go across and that is where you need to put the pliers or screwdriver in to get it to turn out. You can either get a new gasket or some plumbers putty and repair it. I hope that helped.
Oct 03, 2017 | Maax Home
Tub goeson then turns off
This sounds like a bad motor. It sounds as if it is overheating.
You will need the model number and brand of pump in order to find the correct replacement.
rod
us parts center
888-521-6183
Apr 04, 2013 | Maax Pearl By CS42wh Pearl CS42 in White
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    The pump surges where's the impeller
    if your pump is surging then you do not have enough water in the bathtub or you have a jet that is blowing air into the suction fitting. this happens a lot when a jet faces the suction and the air control is wide open. the suction pulls in too much air and causes the pump cavitation (surging). Try pointing the jet opposite the suction cover upwards and see if that doesn't solve the problem.
    Feb 16, 2011 | Maax Pearl By CS60wh Pearl CS60 in White
    Pump stopped working I have sensatouch controls. One day the unit wouldnt turn on when i touched the sensors. Power to the pump is on. also to the heater. Both have power. not sure how to test pump. GFCI...
    you may have a bad switch how good are you with electrical you could go get a regular toggle switch that has the amp load of your pump and wire it to the pump and see if your pump comes on if it does well then you know your sensatouch controls are bad if you think you can handle it and you have a multi meter i will walk you through it
    Jun 29, 2009 | Maax Pearl By CSP5wh Pearl CS-P5 in White
    Broken back massage jet unable to purchase locally
    Hi robrezza,
    Here's the number the Pearl/maax Plant.
    For maintenance, installation or general technical queries about your MAAX products, we encourage you to contact us at: Tel.: 1-888-957-7816 option # 2 Fax: 1-800-201-8308 (418) 387-9086
    Have your tub model when you call. They usually are pretty helpful. Sometimes it goes to voice mail for the tech person but they call back after a bit
    Please rate this response and Good Luck, Phil
    Jan 18, 2009 | Whirlpool Pearl Ballade True Bathtub with...
    Maax Soprano II: One-Piece Shower Module W/o Roof Cap but with One Seat & M Logo
    Top Maax Plumbing Experts
    Donni Steen
    Steve
    obsteiner
    Are you a Maax Plumbing Expert? Answer questions, earn points and help others
