Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer not printing black
I have installed new black ink cartridges twice and the printer still will not printer anything from the black cartridge.
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Won't print anything in black new ink
clean contacts on print cartridge and print head with alcohol
Jul 10, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Epson NX400 works but will not print any ink on the paper
did you remember to pull the tape off the print head before you installed the new cartridge?
May 28, 2009 | Epson Stylus NX400 InkJet Printer
Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Apr 03, 2009 | Canon BubbleJet i560 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Inconsistent Print following installation of a new black ink cartridge
try head cleaning twice or thrice so as to improve the ink flow in the head. wish u success.
Jun 01, 2008 | Canon PIXMA iP1600 Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
