Question about Mitsubishi WD62628 62" Projection HDTV
Wd60738 replaced bulb turned on got a pic then flashing on off pic then squeaking and power off and solid red light
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Double check when lamp went in it engaged the socket (2 pin) correctly and went all the way in----this is where to begin-------whenever you replace a part on a TV or a car etc and suddenly have a new issue suspect something happened when you replaced that part........
Posted on Oct 30, 2012
techman
  • 3130 Answers
SOURCE: replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Posted on Jul 10, 2007
  • 16 Answers
SOURCE: replaced bulb red light still solid lit
you may have a bad convergence chip there is always two in the board if one of them goes bad this is your most common result
Posted on Dec 12, 2009
  • 11 Answers
SOURCE: recently my wd-52327 said it needed new
If you have a voltage meter you can pull the bulb out and check for continuity by placing the probes on the power plugs of the bulb. If you have continuity the bulb should be good, and it may be the lamp ballast.
Posted on Jan 20, 2010
  • 68 Answers
SOURCE: wd-52725 had blue screen no picture or sound
you may be on the incorrect input channel. look for an input or tv video button and choose each input until u get a picture
Posted on Mar 03, 2010
SOURCE: Blinking green light turned to Solid red light -
we are having the exact problem with out tv even after replacing the bulb. have you solved your problem. out tv is 5 yrs old.
www.karlene42@comcast.net
Posted on Aug 16, 2010
Sony tv modelkv27s46 no pic or sound red light blinks
Generally a flashing red light means that it is time to replace the bulb. My tv would not turn on but had a red flashing light I had never seen before . I entered my model online and was able to find tips on how to trouble shoot and advice on how to order and replace new bulb. Hope this helped
Aug 01, 2011 | Sony Televison & Video
Red light solid, green light flashes 10x cycle. no pic/sound
You've got to replace the bulb. I've had my KF-50WE610 for four years. Mine just went out again too. This is the third bulb in four years. The bulbs are expensive too - $100 -$200 each
Jun 11, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
First the red bulb light was flashing and there was no picture. So i replaced the burnt bulb. Now when i go to turn the tv on were the red light means off and the green light mean on (that light blinks 3...
Check Lamp Fan if it stops running when Lamp trys to Light ,Then Lamp will not Power up,or Ballast Board itis what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
Oct 06, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Just replaced bulb. Solid yellow led with no pic
hello make sure the lamp is fitted securely and the lamp cover is fitted securely aswell good luck
regards
shaun
May 21, 2010 | Toshiba 62HM196 62" SD Television
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Mitsubishi WD62628 62" Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
