I dont know how to set up my projector.
I have a a pro x projector and I don't know how to set it up to my desktop,tv,and laptop? Can I get some help please.
What is the output/input setting? it is usually an f4 function on the computer and on the tv it is the audio/video setting.
Posted on Oct 30, 2012
I need help with Corel Paintshop Pro XI
I used to work for Corel and they are a great bunch of people, give them a call and they will help you out.
Apr 27, 2013 | Corel Paint Shop Pro® Photo XI Full...
Protron tv says input signal out of range when connecting laptop via hdmi
The TV can't process the digital signal. It might be out of range.
Nov 26, 2012 | Protron PLTV3250 32 in. LCD Television
How can I get my Gateway desktop to recognize my Projector?
it has to be set up as an additional monitor/display. so, there are settings to set up the displays as either twins, unique seperate or something like that. have not had to do it. but i know that the graphics have to be able to recognize what format the signal is. pc settings change and graphics setttings change. have you done both? the projector should have had instructions? if not look for the manual online.
Aug 23, 2012 | Gateway Computers & Internet
Proper PC Adjustment Parameters?
Hello,Instead of replicating your laptops desktop can you please try extending the desktop. This way your laptop can keep its native resolution and so can the projector. Let me know how it goes.
Nov 17, 2011 | Sanyo Office Equipment & Supplies
I have a hp compaq laptop. i used properly before installing new operating system xp service 2 . but don't use my laptop and my epson projector because automatically don,t display my laptop and...
PC Projector first and Computer next. Usually if the projector powered on after computer you need to use Function keys on laptop normally Function and F4 buttons when pressed simultaneously the computer screen projected through projector. Function keys are identified by green lettering on them.
If you power on projector first and then the computer while they are connected through cable this problem may not arise. Try this and and also Function and F4. This usually fixes the problem. Let us know if you still have problem! good luck!
Sep 10, 2011 | Computers & Internet
I have a Gateway T-6330u and want to connect it to the TV to watch a movie, but I don't know how to do this. I searched the web and found I may need a HDMI cable, but I don't know if there are...
If your TV has a VGA input or the laptop and TV have HDMI run the cable over choose the correct input on the TV "pc or hdmi" my asus auto detects the hdmi stream you may have to right click on the desktop go into video setting and choose the TV.
Aug 22, 2011 | Gateway T-6330U Notebook
My Windows XP is connected to my Epson Powerlite S3, but the screen is blue with the words Source: Computer (Auto) No Signal on it. When I click "Help" on the projector, it takes me to a screen...
'No signal' and 'unsupported signal' messages mean 1 of 2 things, either the VGA output is off(laptop) or the display resolution is set too high(laptop and desktop). Assuming the VGA cable you are using is good, try this:
Desktop: hook the computer back up too your computer monitor & set the computer to the basic VGA resolution. For windows XP, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes!
Drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector. You will need to change the settings each time you switch monitor to projector.
Laptop: by default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue button (on the lower left of the keyboard, usually to the left of control ) and tap the bleu button you just found. Let go & give you're a computer a few seconds to change over. If the laptop screen goes blank, you found the correct button! The display image should now be visible. Repeat this 1 to 2 times to change it back to laptop display.
If you did not see the display on the projector, 2 other issues are possible. First, verify that the VGA output on the laptop is working - connect the laptop to a regular computer monitor & change the display resolution to the lowest settings (see desktop above), then try it again on the projector. If you cannot get an image on a computer monitor, your laptop settings may need to be adjusted in the same dialogue box as the settings. Monitor #1 is the laptop display, Monitor #2 is the external output.
Happy viewing :)
Jun 12, 2011 | Epson PowerLite S3 Multimedia Projector
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
I have a dataprojector, no signal
Then 'No signal' or 'unsupported signal' messages are usually because your display is set too high. To see if this is your issue, hoop it back up too your computer & set the computer to the basic VGA resolution. Assuming you are using windows, right click a blank area on the desktop, click 'properties' on the dropdown menu, click settings. Write down the numbers in the 'screen resolution' and 'color quality' boxes, then drag the 'screen resolution' all the way down to then 'less' side. Then change the 'color quality' to the lowest setting. Click apply, then answer yes (the display will look UGLY - don't worry!!) Now connect your computer back to your projector. If it works, then the resolution you use on your desktop monitor is not supported on your projector. Experiment with different resolutions to see which one looks best on your projector.
Note for Laptop users-- By default the VGA connector on your laptop is off. To turn it on, look for a blue symbol on one of your function (F1, F2, F3...) keys. It looks like an old TV with a line on both sides 'O' (F4 on HP) Press & hold the blue <fn> button (on the lower left of the keyboard, usually to the left of control <crtl>) and tap the bleu button you just found. Let go & give you
Nov 14, 2009 | Toshiba TDP-S81U DLP Projector with...
Acer aspire one won't connect to projector
Hey,
On your desktop, right click, select properties.
now go to settings.
do you see screen number 2? select screen number 2 and check that the screen is enabled if not place a check on the checkbox and enable the monitor, now check the resolution and colors adjust them as you see fit, to move objects to the projector display drag them out from your laptop monitor.
Let me know if you need anything else.
Thanks,
Ekse
Jan 27, 2009 | Acer PD523 Multimedia Projector
44 people viewed this question
k24674
jasbo
jasbo
