Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
My gibson upright freezer is not freezing
Its only a little cold, not freezing
  • Official Brand Answer
  • 4,342 Answers
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Posted on Nov 02, 2012
5 Suggested Answers
SOURCE: freezer
my freezer motor keeps running, and does nor shut off. it is a upright freezer.
Posted on Oct 05, 2008
SOURCE: upright freezer not cold enough
Is the higher the number on the selection knob of my upright frigidaire freezer a colder or warmer setting?
Posted on Feb 17, 2009
  • 401 Answers
SOURCE: Gibson Upright Freezer
Is it a self defrosting? Or not? And how did you defrost it?If you scraped and chipped the ice away, you may have poked a hole in the evaporator and the refrigerant (freon) leaked out.
Posted on Jan 03, 2010
  • 384 Answers
SOURCE: Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Posted on Jul 09, 2010
Upright freezer not freezing food and ice forming on back wall
is the top of the freezer full where it can breathe remove something to help it breathe
Sep 10, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
dear sir
thank you.
Jul 05, 2010 | Frigidaire Freezers
I need to know what the numbers mean on the temperature setting (1-7) for my Gibson Upright Freezer? What is best recommended temperature?
The highest number is the coldest setting.When you fill it up with food to freeze , set the freezer to the coldest and after everything is frozen .set the control to the middle.
Oct 05, 2009 | Freezers
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Nov 28, 2008 | GE 13.7 cu. ft. General Electric Upright...
Freezer
hi thanks for the question first is the compressor running if it is & not cooling . your freezer has lost its refrigerant if so not worth repairing worstthing people do is not use a freezer for a long period of time its ok for fridges as they are built different thanks the appliance doc
Sep 26, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
GIBSON DEEP FREEZE IS RUNNING BUT EVERYTHING IS THAWING OUT
Might try unplugging for a few hours and then plug it back in. There is a possibility that it slugged the compressor and there is a restriction in the line. Sometimes when the compressor fails to stop running in cold air the liquid gets back to the compressor. It can cause a bit of gunk to be picked up out of the oil and carried to the expansion line and plug up the line. Maybe turning it off will let the plug fall free and not replug the line. Worth a try anyway.....
Feb 07, 2008 | Freezers
Open Questions:
See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
427 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
