Question about Mitsubishi WD-60738 TV
Replaced bulb then squeaking sound and no pic
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Go back over what you did to make sure lamp is correctly in--a common issue on this brand is when putting the lamp in the socket that it engages gets bent or shoved to one side---with lamp out look to see if the two pin socket the lamp plugs into is not bent away.....
Posted on Oct 30, 2012
Wd60738
Double check when lamp went in it engaged the socket (2 pin) correctly and went all the way in----this is where to begin-------whenever you replace a part on a TV or a car etc and suddenly have a new issue suspect something happened when you replaced that part........
Oct 30, 2012 | Mitsubishi WD62628 62" Projection HDTV
Red light solid, green light flashes 10x cycle. no pic/sound
You've got to replace the bulb. I've had my KF-50WE610 for four years. Mine just went out again too. This is the third bulb in four years. The bulbs are expensive too - $100 -$200 each
Jun 11, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Panasonic PT-47WX33G doesn't start up (no picture no sound). Power indicator blinks 5 times while I hear a repeating squeaking sound inside the TV (squeak squeak squeak squeak squeak). I replace...
If your set is blinking 5 times it is the HV power supply.
You most likely have a sorted Horizontal Output Trasistor. (HOT)
If you have any further questions please respond to this post.
Thanks
asnowman
Jan 22, 2011 | Panasonic Televison & Video
Just replaced bulb. Solid yellow led with no pic
hello make sure the lamp is fitted securely and the lamp cover is fitted securely aswell good luck
regards
shaun
May 21, 2010 | Toshiba 62HM196 62" SD Television
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
No pic with sound and turn off by itself with a
The red light is a status indicator that means your tv needs to be serviced. Most likely your bulb burned out or failed. You can purchase a replacement bulb online. I have solved a few questions on how to replace a bulb on this site. Check my profile for those posts if you need help with that.
Jul 01, 2009 | Mitsubishi WD-60735 Projection Television
Changed bulb and still no picture or sound
hello i think when you put a new bulb in you have reset the bulb counter good luck
shaun
May 30, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
No pic No sound
your bulb is connected to all the audio
the bulb blew out and you need to have it replace local cuircut city has a repair man on call for this
Feb 16, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Toshiba 52hm84 DLP buzzing sound after replace bulb?? no pic
You have bad capacitors in the power supply that took out the regulator, or the ballast circuit is defective. Not really a repair for the novice. Good Luck
Nov 06, 2007 | Toshiba TheaterWide 52HM84 52" Rear...
Mitsubishi WD-60738 TV Logo
93 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
