Question about Frigidaire FEB30S5DC Electric Single Oven
CUTOUT FOR DISCONTINUED MODEL
HI,
COULD YOU PLEASE VERIFY THAT THE CUTOUT DIMENSIONS
OF A FRIGIIDAIRE SINGLE OVEN #PLEB30S9DCA ARE THE SAME AS THE NEWER MODEL # PLEB30S9FCA?
MY CUSTOMER BOUGHT OVEN WITHOUT AN INSTALLATION
MANUAL.
THANKS!
JJ
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
What are the cutout dimensions of a Magic Chef 59GN?
Need to find out what size oven to buy to replace Magic Chef : 59GN -5TVW
May 25, 2013 | Magic Chef Ovens
Trip swich went when turned back on no power in oven at all
Hi intial problem will probably be a faulty heating element locatated behind the panel at the back. the zbf260 has no clock but if its a zbf 360 set the clock before the oven will function. otherwise the fault has damaged another component on the oven. which can be in order of most likley.fuse if on 13a supply/ thermostat/ selectorswitch/ thermal cutout/jw
Feb 09, 2011 | Zanussi ZBF260 Electric Single Oven
Is this model 27" or 30"
It is a 30". Your model number has the dimensions for your oven included in it.
The best of luck to you. Please check us out at:
www.accurate-appliance-service.com if we can be of any further assistance.
Oct 24, 2009 | Amana AOES3030 Electric Single Oven
Electrolux electric wall oven not heating
You should definitely have continity through the themostat. I would replace these first. When you get to the parts dealer bring your meter and check yo see if you have continiuty through the new one first before you pay for it. I hope this helps.
Dec 10, 2008 | Ovens
Frigidaire FEB30S5DC Electric Single Oven Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
