Question about Toshiba Televison & Video
2008 regsa toshiba 46 inch flat screen tv
2008 models
  • 4 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
budmrtn
  • 11361 Answers
SOURCE: The *audio cuts out occasionally on my 42 INCH
Try using the Audio line out RCA jacks feeding a PC powered speakers to see if it does the same thing, If it is OK, then the problem will be in the power amp sections that drive the speakers.
Posted on Oct 30, 2009
SOURCE: toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
Posted on Aug 22, 2010
SOURCE: vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Posted on Jan 25, 2011
  • 302 Answers
SOURCE: I have a friend that
http://www.samsung.com/us/support/
You can get the manual from the samsung website.
Posted on Jun 08, 2011
2008 46" Toshiba Regza, has bad picture when cold
It would help to see a pic or video. The fact that hitting the top side clears up the picture leads me to believe that you may have a bad LCD panel tab. If this is the case, the only true fix is to replace the screen, BIG $$$
Nov 25, 2012 | Toshiba 46XV540U 46 in. LCD HDTV
How can we start a class action law suite against toshiba
No use. Do you think they will respond to your suit.
Poor man!!!!
Jun 25, 2017 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Toshiba 46 inch flat screen model number 46rv53ou
Click here to download the user manual to your tV. Go to page which displays its specifications. You will get all details there.
Apr 18, 2012 | Toshiba Televison & Video
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Toshiba 46 HD TV-1/2 Screen going out
Aug 02, 2010 | Toshiba Regza 46RV535U 46 in. LCD HDTV
I have a vertical red line on 46 inch lcd it is 2 weeks out of warranty model no TOSHIBA 46 XF355DB what is best course of action thanks
I also have this problem on a set that is a year and a half old. The repair man was here yesterday with some parts that didn't fix the problem...he said the screen needs to be replaced! Luckily I bought from Costco, who extends the warranty by a year, so we won't be out any money. They will be getting back to me with what they are going to do...repair or replace...depending upon what is most cost effective for them. I will be trying to purchase extended warranty for this TV, if repaired, or new TV, if replaced. Too many horror stories out there on all brands not to.
May 16, 2010 | Toshiba 46XF550U 46 in. HDTV LCD TV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
