Question about Task Force 2000 PSI Electric Pressure Washer NEW 6127
Need wiring diagram for tf 2000 pressure washer
Need to know the connections for the power from the switch to the motor
I HAVE A 2000 OLDSMOBILE SILHOUETTE. MY REAR WIND SHIELD WIPER STOPPED WORKING. HOW CAN I FIX IT
First you must pull off the trim panel and expose the mortar and wiring to the motor, then test for power and ground, if present test the motor.
Aug 29, 2017 | Oldsmobile Cars & Trucks
2005 ford 150 . wipers don't work but washer still does work . could it be a fuse or wiper motor. or what? Ted H ope you can help thanks
Do you know how to test automotive electrical circuits ! Using a wiring diagram and a volt meter ? test power to the wiper motor .
Control from the switch .
http://www.bbbind.com/free_tsb.html free wiring diagrams . Enter vehicle info. year , make , model an engine size . Under system click body & accessories , subsystem click wiper / washer . click the search button then the blue link . Look at the diagram for pin # 's an wire colors , see fuse at top of diagram . Check B+ power with volt meter . Check the inputs from the wiper switch to the motor . If all the power an inputs are good , replace the wiper motor .
Jun 12, 2017 | Ford Cars & Trucks
Wiring diagram for replacement motor
Here is a pdf file maybe this will help.
The power cord has three wires there should be a green =ground black hot white neutral.
http://www.greenworkstools.com/uploads/documents/51012_1700PSI_Pressure_Washer_E_Manual.pdf
May 15, 2015 | Greenworks 1700 PSI 1.4 GPM Electric...
A CH pressure sprayer PW175000AV Ser# 00842 was electrically taken apart without noting how wires were to be reattached. There are 4 male spade connectors on rocker switch which works fine. Power has...
Hello Woodnflies,
I understand that you need to rewire your pressure washer. I understand that you already have the switch wired and the motor wired as they are working. You need to power the pump that has a white (common) male and a black (hot) female. You what spade connections do you have open to connect too.
You should have a black and a white that have nothing attached to them this is where the pump wires are going to attache in the circuit.
Thank you for choosing FIxYa.com
Justin
May 05, 2011 | Campbell Hausfeld PW1750 Electric Pressure...
I get an F11 error. Washer will not start in any mode.
GHW9150P Tech sheet:
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor. Refer to the
"Water Temperature Sensor" section. Check
connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
F-07 Motor control unit error
Possible causes/proceedure:
2. Check wire harness connections between the drive motor and
3. Plug in washer or reconnect power.
4. Check the MCU by looking for operations of the drive motor.
5. Check the drive motor for powered rotations.
F-09 Overflow Condition
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. the pressure switch for proper operation.
F10 Motor control unit heat sink thermal trip
1. Check for proper installation, verify the unit is not located
near a source of heat and has proper ventilation.
3. Check wire harness connections to the MCU, the motor,
4. Check the drive system for any worn or failed components.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
F11 Serial communication error
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
2. Check wire harness connections to the MCU, the motor, and
3. Check the drive system for any worn or failed components.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
F13 Dispenser circuit error
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
4. Check dispenser motor for powered rotations.
F14 The dreaded EEPROM error
The Central Control Unit (CCU) receives its data from an EEPROM
onboard the CCU. If there is an error reading this data it will cause this
error. Possible causes/proceedure:
¦ A power glitch may cause this error.
1. Unplug washer or disconnect power for two minutes.
2. Verify CCU operation by running a Diagnostic test or any
cycle.
F15 Motor control unit error
If the MCU detects multiple resets or errors during a wash cycle it will
go into this error mode. Possible causes/proceedure:
3. Check drive belt.
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
touch-pad/LED assembly and Central Control Unit (CCU).
F du Door unlock error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to
unlock the door 6 times before displaying the error code.
¦ Door lock mechanism is broken.
¦ Door switch/lock unit failure.
1. Check door switch/lock unit for foreign objects.
3. Check wire harness connections to the door switch/lock
unit and Central Control Unit (CCU).
NOTE: The door switch/lock unit can be manually unlocked. See
"Manually Unlocking The Door Lock System".
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
¦ Door lock mechanism is broken or removed from door.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
or kinked.
6. Check drain pump.
7. Check the pressure switch.
cycle.
Tech sheet link:
https://servicematters.com/secured/docs/wiring/Tech%20Sheet%20-%208182277.pdf
Mar 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
07f error code... duet washer W9150
Tech sheet on this model:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer fills up but drum does not turn. After this part of the wash cycle has elapsed the washer will contniue normally with the rest of the wash (i.e. spin....). So not a fuse problem. Not sure of the...
If your motor does not run after the washer fills, then your failure is in the water level pressure switch, the timer, the drive motor or the wiring harness. The pressure switch would be the first component that I recommend checking. With the washer filled to satisfy the pressure switch, you can disconnect electrical power and pull the tan and violet wires off of the pressure switch. With a volt/ohm meter, measure the resistance across the leads of the pressure switch where the tan and violet wires were connected. You should measure near zero ohms of resistance with the washer full of water. If not, then your pressure switch would need to be replaced.
Jan 07, 2011 | Kenmore 43042 Front Load Washer
This is the second time this problem has occurred. The machine simply won't fill. The door locks and then nothing. Last time it resolved itself after about 4 hours. This time it's been overnight and...
You could check your inlet hoses for kinks You inlet screens on the valves for clogs.themobilian_473.jpgthemobilian_474.jpgall this stuff you can do a filter clean out as shown HERE
Your tech sheet info:
on all the way.
the inlet valves.
F-2 Long Drain
display.
or kinked.
or kinked.
cycle.
MCU connectors.
the dispenser.
cycle.
or kinked.
cycle.
Tech sheet link:
Dec 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F32
The F32 error code indicates a water level pressure switch failure. This is normally caused by wiring connection problem or a failed pressure switch. If you are able to unplug the washer and remove the top panel, you can check the wiring connections between the control board and the water level pressure switch. To remove the top panel (with the washer unplugged), take out the screws at the very back of the top panel and slide the panel back and then pick it up and remove it from the top of the washer. The pressure switch is on the top of the right side panel toward the back of the washer.
If the wire harness connection between the pressure switch and the control board is okay, then you will probably need to replace the pressure switch to correct this problem. The part number for the pressure switch is 8181695. You can order this part from the Sears PartsDirect website www.searspartsdirect.com .
The F28 error code indicates a communication error between the main control board and the motor control board at the bottom of the washer by the drive motor. A loose wiring harness connection can cause this problem. It can also be caused by a failed motor control board, a bad drive motor or a defective main control board. You may be able to check the wiring harness connection to the motor control board by unplugging the washer and removing the bottom from service panel. To remove this panel (with the washer unplugged), take out the screws at the very bottom of the panel and then pull the panel down and out to remove it. Access to the motor control board may be limited. You may be able to check to make sure that wiring connections are firmly secured on the motor control board. If the connections are okay and you continue to get the F28 error code, you may need to replace the motor control board.
Nov 02, 2010 | Kenmore HE2 Plus Front Load Washer
My kenmore washer is overfilling even though I changed the pressure switch
The clear plastic tube runs from the pressure switch to the air dome on the lower right-hand side of the wash tub. If the air dome end of the hose were loose, water would begin to spill out of the bottom of the washer when the level in the tub reaches only a few inches.
If the washer is filling the tub completely, but your pressure switch is not shutting the water off, you will need to confirm you have a good electrical connection, and that you do not have a small hole in the air hose somewhere. It is possible for the air hose to develop leaks where it contacts the washer casing and begins to chafe. If your electrical connections to the pressure switch are secure, trace the wires back to the timer and make sure you have good continuity. There should be a wiring diagram located under the operator console. Please refer to the following link for instructions on how to access the inside of your washing machine:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
I know the instructions are for replacing a motor coupling, but the steps are still the same for opening the console and removing the outside washer casing. Please let me know, if you require further assistance. If you don't get anywhere with this advice, please post back with your complete model number. It may help me further with diagnosing your problem. I hope this provides you with a solution.
PS I apologize for taking so long getting back to you.
Jun 29, 2008 | Kenmore 24032\24036 Top Load Washer
Task Force 2000 PSI Electric Pressure Washer NEW 6127 Logo
326 people viewed this question
Top Task Force Garden Experts
Tom Chichester
Bill Boyd
Are you a Task Force Garden Expert? Answer questions, earn points and help others
