Question about Polaroid FLM-2011 Television
Polaroid FLM 2011 wont connect to cable - Polaroid FLM-2011 Television
    Genius:
  • Polaroid Master
  • 2,432 Answers
Reset with cable box doesn't work?.
Posted on Oct 30, 2012
3 Suggested Answers
SOURCE: POLAROID FLM-2011 REMOTE CODES
My cox remote guide lists for the Polaroid TVs the following codes:
LCD TVs: 1276 and 1316
TVs: 0765, 0865, 1276, 1314, 1316, 1326, 1327, 1328, 1991, and 1992
I hope one of them works.
Posted on Oct 12, 2008
eagle338
  • 4889 Answers
SOURCE: I have a Polaroid 20" lcd FLM-2011 , I just
It simply means that the backlight inverter you have received is faulty. The faint image means that the T-con is functional but there is no backlight to actually illuminate the picture on the screen!
Posted on Dec 17, 2010
I can't find the manual to download. I lost my copy for my FLM 2011 TV
Hello
Get into this link where you can download the user manual of your poloroid FLM 2011. It is an adobe acrobat document. You must have Adobe Reader installed in your system to read it. Reader can be downloaded and installed from Adobe.com site for absolutely free. OK
www.polaroidsupport.com/polaroid/docs/FLM-2011-ServiceManual.pdf
Jun 27, 2011 | Polaroid FLM-2011 Television
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
While watching the TV the picture suddenly went out - still have sound. Turning the TV off and on again does not help - the POLAROID Logo displays, but when the station connects - still no picture
possibly external power supply faulty under load it may fail these power supplies ofen have capacitor failure open the power supply to check for leaking/bulging/swollen capacitor is around 2000uf rated at 12v
Apr 28, 2009 | Polaroid FLM-2011 Television
Expensive cable wires
it will inprove it a little, but usually is a bad cable connection, or week signal, that will cause fuzzy picture
Jan 09, 2009 | Polaroid FLM-2011 Television
FLM-2011 will not turn on
does anyone have the answer to this problem. it seems like alot of polaroid tv's are doing this. please if anyone knows how to fix the tv and get it to turn back on and not flash red to blue anymore, please let us know.
Jun 28, 2008 | Polaroid FLM-2011 Television
Polaroid FLM-2011
connect the leads of a voltage meter to a short cable tv jumper cable connected on one end to the f-connector on the back of the tv, positive lead to the center conductor and ground to the outside of the cable fitting with the meter set to ac setting. A normal tv will show a couple of volts but nothing higher. if you have higher voltage there is a problem with the tv.. If you hook this cable to the catv feed from the outside of the home which connects to the tv and you test in the same way and there is voltage then there is a problem with the cable tv or a power grounding problem. If there is voltage on the incoming cable call the cable company and the power company to find the problem before you end up with a possible fire.
Jan 05, 2008 | Polaroid FLM-2011 Television
Polaroid FLM-2011
On Polaroid tv's ther is no individual parts available. You have to replace the control module.
Send me the model and serial number and I will give you a Quote on the cost of the module.
Lou Margo
Allied Electronics
908 276 8987 cel 513-490-0759
loumargo@verizon.net
Nov 28, 2007 | Polaroid FLM-2011 Television
Sep 10, 2007 | Polaroid FLM-2011 Television
Polaroid FLM-2011 Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
