Hi, o have a Samsung LN40A530 HDTV. i can hear sound but only see verticle colored lines everywhere. this when i try satellite TV, dvdw, or just try to see the menus. any help is great. thanks.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The lines can be from the main which processes all information to the screen----no single answer---not likely a power supply issue but several boards are possible-----Google that model with "parts" as there are several sites that list by model number all the boards with prices.
The worst case is the set got moved etc and the Panel is causing this which is fatal---screen unit has connections inside which cannot be got at.
Posted on Oct 30, 2012
  • 87 Answers
SOURCE: Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Posted on Feb 22, 2008
  • 139 Answers
SOURCE: verticle black lines on mitsubishi dlp tv screen
Press the Menu Key on your remote. If your menu shows clearly on the screen, then there is a problem with your source.
Posted on Mar 06, 2009
SOURCE: 5 mostly green verticle lines on all digitle channels. HD ok.
I just called customer support and my issue is now fixed, to my extreme surprise.
It sounds silly (and a tad embarrassing), but here's what I did:
1) Unplug the TV
2) Wait 30s
3) Plug the TV in
4) Test
Apparently even if the TV is "off" for a few days it never fully shuts down unless the power is unplugged. Not sure if this will help anyone else, but I had the exact same problem others are describing. Good luck!
Posted on May 06, 2009
SOURCE: adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Posted on May 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Posted on Jul 10, 2009
Hi,I have a 46"Samsung Led TV,If i use the tv for 1-2 days i wil get some verticle lines in Center, Left&Right Side of TV. If i stop for 1-2 days thr wil be no line for 1-2days and again it wil starts
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "Line fault" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 02, 2016 | Samsung "Un46 D7000 46"" 3 D Led Lcd Tv...
I have colored verticle lines when I watch tv but none when I play a dvd. I changed out HDMI cables but it did not help. What should I do next?.
Are you using an antenna, cable box or satellite?
If you are using a cable box or satellite then the problem lies withen the box or sat.
Mar 28, 2015 | Samsung LN46A650 46 in. LCD HDTV
Samsung Plasma HP4252 type SR42P5 verticle blue lines across entire screen
First off there isn't a timing board in a plasma TV. I would guess you have a bad y-sus board.
Feb 20, 2018 | Samsung HP-R4252 42 in. Plasma HDTV
Purple and blue screen on dlp tv
Sounds like a problem with the Vertical Video Card.
Have fun finding one. If your TV is still under warranty... send your TV off for repair.
Oct 03, 2012 | Samsung HL-R5656W 56" DLP HDTV
TV made a big popping sound, and then a crackling
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php That crackling sound could be of the color wheel:The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9601073A you can find original here:http://www.discount-merchant.com/Samsung-BP96-01073A-lamp-p/samsung-bp96-01073a-lamp-oem.htm?Click=48173 .Have a blessed one!
Apr 02, 2010 | Samsung HL-R5668W 56" HDTV
I have a Sony KDFE50A10 50 inch HDTV When I turn it on for it has the lines verticle on it it takes a few minutes and then clears...tv or cable?
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or vertical lines.You will need to replace the light engine.God bless you!
Oct 20, 2009 | Sony KDFE50A10 50" HDTV
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Jun 11, 2008 | Televison & Video
Verticle lines on screen
This is a very easy fix. Your cable box is not grounded correctly. To fix this you need a AC Plug adapter. This will change your TV ac plug from a 3 wire to a 2 wire. This may sound funny, but trust me on this. I have fix a lot of TV in NY doing just this.24001fc.jpg
Sep 10, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical black line
does this verticl line go all the way form top to bottom or is it about 5-7 in long in the center of the screen and does it some times change in color with the picture.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
if you could post a digital picture of this tv I can make a determination, it could be the panel or one of the boards inside the set
Dec 14, 2006 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
