Question about Dell Inspiron B130 Notebook
Sound when i play anything with sound the sound that comes out sounds like it is skipping
Hey, seems the choppy sound is due to the revision of some systems firmware with the TSST drives, on my system I downloaded what is touted as a Server update for the TSST TSL462C the file was R147358.exe, if flashed the CDRW/DVD combo drive and viola, it seems that 99% of the audio skipping is gone, don't know about other drives, but the Sigmatel driver on my system is version 5.10.0.4995 if I remember I got this driver off the LG site for Notebooks.
Hope it helps.
Steve in Texas
Posted on Feb 22, 2009
    Problem Solver:
  • 14 Answers
Your CPU may be overheating. Try sitting laptop on some legs.
Posted on Jan 03, 2009
I have replaced my hard drive with a SSD. The computer is working perfect except that it now refuses to play any of the audio files that it used to play.A message comes up saying the file format is no
It sounds like your sound drivers are not installed or corrupted. Does it play any sound at all? For example the windows startup sound. Look in device manager and see if your sound device is working properly. There maybe more than 1 device. If so then go to your sound properties (right click speaker icon on taskbar) and see if there is another device you can use to play sound and make that one your default choice. If this doesn't work then look for updated sound drivers for your particular device. Hope you get it working.
Jan 08, 2015 | HP Pavilion Computers & Internet
Pioneer vsx-522k Receiver Sound skip on SD only
use the hdmi from player to tv, use seperate coax or optical cable from player to reciever for your sound
Mar 02, 2013 | Audio Players & Recorders
Just hooked up an fiber optical cable(digital optical) for my bose surround cinimate2 sound to my ps3 to the bose reciever, Now i get good sound, but when i play a dvd it skips and pauses, is it the ps3?...
gosnell6960
Most likely the default format of the video that you are playing is not supported buy your receiver. You may try to go into the audio setup and switch it to another format and/or try a disk that supports other audio formats to see if you still have the problem. They any are always coming out with newer versions of dolby and dts. So some times the new version is not fully compatible with the older receivers.
Let me know i you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
Well my computer is in safe mode in i want to know how do i get my audio service working because right now its currently blocked in i just want to know how do i unlock it so i can hear music in other types...
there is no unlock, safe mode allows you to correct the problem.
You may experience any of the following symptoms on your Windows XP-based computer:
  • You do not hear sound from the computer's speakers or headphones.
  • A sound seems to be played, but you do not hear anything.
  • A sound is played, but it stops suddenly.
  • The sound skips or misses in some areas.
  • The sound is distorted or scratchy.
  • The computer stops responding when a sound is played.
  • The computer restarts when a sound is played.
  • You receive an error message when you try to play sound. Error messages could include the following:
Solution: here---> http://support.microsoft.com/kb/307918
Nov 24, 2009 | Acer Veriton 6800 PC Desktop
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Acer Aspire 6530 sound card
Looking at VIA's page on the P4M266 and scrolling down, it shows you're using South Bridge VT8233/8233A/8233C. Going to VIA Arena and selecting XP, Audio, and VIA AC97 codecs incorporated into VT8233, VT8233A, VT8233C, VT8235 and VT8237/R South Bridges takes me to the audio driver you need. Just click the above link and get it.
also u might have to un-install driver and reinstall it! but PLEASE DO NOT UNINSTALL ANYTHING WITH OUT HAVING THE DRIVER CD or all the hard and software needed!
Mar 22, 2009 | Acer Aspire 6530-5143 Notebook PC
When playing DVD sound stutters and gets slower and slower
you have to look for audio uploads for your machine additional audio bass drivers
Jan 18, 2009 | Toshiba Satellite M105-S3021 Notebook
Sound Is Skipping
Have you installed anything else on your pc
is this xp
Jan 16, 2009 | Dell Dimension 8400 PC Desktop
Sound skips in and out at the beginning only
Try updating/re-installing your audio drivers from the laptop website, or from manufaqcturer's website. Also, update your Chipset drivers.
Hope that helps
Tim
Dec 19, 2008 | Computers & Internet
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Dell Inspiron B130 Notebook Logo
162 people viewed this question
Alun Cox
