Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Will not get cold after cleaning out
Power was cut off while oofshore for two months came back and took it outside to clean maggots and nastyness sort of like after a storm. it needed a deep cleaning so itook everything off and out brackets back of freezer panel exposing everything then scrubbed with bleach and turned a water hose on it. put everything back together and it runs but will not get cold at all. oh and blew out the back and bottom with air
    Top Expert:
  • Admiral Master
  • 9,472 Answers
What is the model number? Does the compressor kick on?
Posted on Oct 30, 2012
4 Suggested Answers
  • 958 Answers
SOURCE: Icemaker in Admiral side by side refrigerator/freezer stopped working
see if you can bleed the air trapped in the water line to the ice maker. if air is trapped, water would not be flowing and it would take only a few seconds for the solenoid to be open to let water flow.
see if you can hot wire the solenoid to let water and air out of the tube long enough to bleed the air and hopefully, the ice maker would work continuously.
tnx 4 using fixya,
drcool
Posted on Oct 08, 2008
  • 183 Answers
SOURCE: Hi our fridge is building
The problem is caused by the failure of either the defrost thermostat or defrost heater. In any case, replacing both the defrost heater and the defrost thermostat is recommended, and that would solve your "ice in freezer" problem.
Posted on Jan 16, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have an admiral fridge
hello again,
Sorry to hear that the drain is clear and not the problem, some of the other things that cause that water are;
Freezer door gasket...is it curled up in the corners espicially on the hinged side so air is leaking in and condensating resulting in water
The tube that send water into the icemaker is partially frozen so when water enters the icemaker it's being sprayed and dripping to the bottom(if thats the case ice would probably be built up all over the freezer)
The door for the ice dispenser isn't fully closing and will cause condesation just like the door gasket would
Good luck,
GENE
Posted on Oct 12, 2011
Help. I shut down my refrigerator when I moved. When I opened the door, I found the refrigerator full of maggots. I used clorox to clean it but I heard there could be eggs that I could not reach. Is...
Maggots are the larvae that have hatched from insect eggs. Yes, there might be eggs somewhere still in your refrigerator. I would suggest that you locate an insecticide (a bomb type perhaps) and set it off in your refrigerator BUT UNPLUG THE REFRIGERATOR FIRST. Close the doors and let the refrigerator stand for a week. After that time, you will need to carefully wipe down all surfaces with a mild soap solutions. Then rinse well. If there are still lingering odors you can wipe again with baking soda solution or you can place activated charcoal in the refrigerator to absorb the pesticide odor. I had this same thing happen in a foods lab with a microwave oven. I used this procedure and never had maggots again. You don't have to be a dirty person to have problems like these! I hope this helps. If it does, please come back to Fixya and rate my advice!
Jul 28, 2011 | Refrigerators
Is it possible to have refrigerator cleaned and
take it outside asap.the mould can spread everywhere....to kill the mould,spray copious amounts of cold water/clorine bleach everywhere,avoiding electrics,do not soak cabinet.leave open to "gas off"then clean out with bicarb if you can take off door seals soak them in bleach brush clean.the last one i did took me ALL DAY
SAFETY TIP..wear rubber gloves...on a nice breezy day.
Mar 29, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Automatic defrost refrigerator not cold enough
manually defrost unit. no hot water... clean out drain hole with thin wire with a small cloth tied to end (very small amount ) dipped in clorine bleach. blow out if wire not available. clean around fan housing clearing any dust particles...plug in and check temp.all should be fine....manual defrost/clean drain, wash out interior with bicarb every 6 months.hope this sort it out ....
Feb 09, 2010 | Refrigerators
Rudd 2.5 combo ac/heat unit
This could be due to a freon leak or the condenser unit needs cleaning also the evaporator in the attic should also be cleaned and inspected. If cold sweat is not seen outside on the large line going into the outside unit I believe you may have a freon leak. Sea Breeze
Aug 27, 2009 | Ruud UAMB Air Conditioner
Our AC unit stopped blowing cool air. The Unit runs but no cold.... We just changed the filters a month ago. My wife swears she hears a beeping tome every couple of minutes. The unit is a CPLE 30-1C????
if you have not clean the outside unit,,and it is dirty will not breathe right and cause the air to be warm try this,, mix clorox and water into a sprayer,cut unit off clean coils good.hope this work for you,,one thing to check before you clean the unit,,while it is running go out and look inside the unit if you see ice on pipes you are low in gas !
Aug 11, 2009 | Heating & Cooling
After cleaning blower on the furance outside unit will not start.
If you took the door off of the squirrel cage fan for a while the freon gets so cold the compressor cannot pump it. I will trip the outside breaker. Just let me know if during the process did wiring get moved around. Let me know, Sea Breeze
May 23, 2009 | Weather King 10AJA3001AH Air Conditioner
Dell 8600 Won't Power On
Try taking out the memory and put it back it. I probablly needs to be reset
Dec 10, 2008 | Dell Inspiron 8600 Notebook
Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Nov 16, 2008 | Poulan Pro Chain Saw 46cc 20"
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jdthefixer
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
