Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Selecting Single Channel input for Lambda in Windows 7
I'm trying to use my Lambda as an input device for Xsplit, but due to the fact that Windows 7 forces me to a select a 2 channel input (no single channel options are available) in Device Manager I can only be heard over the left audio channel. Is there anyway to get Windows to recognize the Lambda as a mono input? There is no way to alter the inputs to Xsplit, it relies entirely upon the settings in Device Manager to determine microphone settings. If I was using my Lambda simply for recording this would not be an issue at all, but since I'm using it for live broadcasting it's become impossible to fix.
2 Suggested Answers
SOURCE: Icant record more than one track at a time.
Welcome to my nightmare. I have been having nothing but grief with this box. Try going into your control panel and click the hardware tab. Under device manager, look in the sound, video and game controller and see if your Lexicon Input 1-2 an 3-4 are enabled. If not right click and enable them.
Posted on Sep 16, 2009
Tecra A11 can't see all of 3TB drive
Support for Disk Drives Beyond 2.2 TeraBytes (TB) and 4K Advanced Format Sectors
Most legacy systems built before 2011 have a traditional PC BIOS. This type of BIOS uses a Master Boot Record (MBR). The MBR Partitions can define a disk drive capacity up to 2.2TB. Windows operating systems that boot from an MBR are therefore limited to 2.2TB per MBR. A 3TB disk drive in a legacy BIOS and Window system will need a DiscWizard device driver to access the full capacity of a 3TB disk drive. Two partitions will be necessary because of the MBR limitation. The device driver mounts the capacity above 2.2TB with another MBR which looks to the system as a second virtual "physical" device.
GUID Partition Tables (GPT) can define drives larger than 2.2TB. You can use GPT today on any Windows 10/ 8.1/8/7 and Vista system as a non-booting data drive. Windows can only boot a GPT partition on a new type of BIOS called UEFI.
UEFI BIOS desktop systems are new since 2011. Windows 10/8/8.1/7 64-bit and Vista 64-bit operating systems support booting from UEFI and GPT without the need of a non-Microsoft device driver. This is the Windows native solution for booting a 3TB drive to a single partition.
Quick facts about Windows and 3TB drives:
  • Windows 10/8/8.1/7 and Vista support GPT 3TB single partitions
  • Windows 10/8/8.1/7 and Vista can only boot GPT on systems with UEFI BIOS
  • Windows 10/8/8.1/7 and Vista can mount a GPT non-booting data drive
  • Intel RST device drivers before v10.1 do not support 3TB disk drives
  • Windows systems with Legacy BIOS and MBR boot drives are limited to 2.2TB partitions
  • Windows XP does not support GPT
  • Windows XP sees a 3TB drive as 800GB on boot or data drives
  • DiscWizard software can install a device driver which opens the full capacity of a 3TB. You can use it to create a second partition for the capacity above 2.2TB
Sep 27, 2017 | Toshiba Computers & Internet
How to fix and install the built in microphone of my P-78What's your problem?
LOL, Windows 7 is like it's predecessor Vista. Same people wrote it.
Have you made sure you have the mic's volume turned up? Have you selected the mic in the Audio and Sound properties?
Look at the Audio and Sound properties in the Control Panel and make sure everything is ok. The Mic has to be selected as a Recording Device.
Apr 10, 2012 | Computers & Internet
My stratego game will not play on window 7 was wondering if there is a patch for it?
Hi Tony,
Have you tried to run the game using Windows compatibility mode?
You can do this by right-clicking on the game's launch icon and selecting "Troubleshoot compatibility" from the drop-down menu.
Select the operating system from the list which worked with your game.
Windows 7 will apply settings which replicate the version of Windows you choose from the list.
Best wishes,
Graemevm
Jan 10, 2012 | HP Hewlett Packard Pavilion Slimline...
Brand new, distorts intermittingly. Used same Speakers with other similer amps Mackie 808 Yamaha etc. with no problem . It sounds good when it does''nt distort
Common causes of this are improper level setup. You MAY be overdriving the inputs. Use the pad buttons to limit the input for higher output devices. Saturating the input(s) will cause bad distortion. Observe if any of the clip indicators are coming on. If they do, then use the pad buttons. If they still come on due to very high output device, you MAY have to use an external attenuator. Every mixer has different characteristics and some can accept a wider inout range than others.
Jul 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
I have a turntable with a white and a red male RCA output cable. I am trying to hook it up to a Marathon DJ-1000 amp which has two TRS input channels - Channel 1 and Channel 2. Should I buy a twin female...
If I understand you correctly each channel has a single input in the amp, then yes! white goes into channel 1 and the red plug goes to channel 2 this way your signal will be stronger which translates into louder sound.
Jan 25, 2011 | RCA Audio Players & Recorders
When i make phono input..The Volume come very big.And all other input selecter volume come normal.
As long as the phono input is only being used for a record deck the most likely cause is a faulty magnetic cartridge pre-amp. If you are connecting any other device to these sockets, remove it and place it in another socket. If you haven't got enough sockets you can get a switching box to solve the problem. If you are getting the problem due to a record deck, make certain it hasn't got a built in pre-amp first, check the cartridge and wiring to it and all deck connections. If still no luck then you will find that you need to replace the pre-amp. It will be a single IC, which can be found by following the wiring from the phono sockets inside the amp.
Sep 14, 2010 | Technics SUV500 2-Channel Amplifier
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
My toshiba L310 laptop webcam dosenot work & that happend after i upgradded my OS from Vista to win7
1. It's a driver compatibility problem with Windows 7.
2. Install the driver for web camera which is compatible on Windows 7 using the bundled CD/DVD.
3. Update the web cam driver using Windows Update!
4. Restart the system.
please rate this advice if it hepls...tc! :)
Nov 01, 2009 | Toshiba Satellite Pro L300-EZ1501 Notebook
Open Questions:
See all Lexicon Lambda Usb Desktop Recording Interface Questions
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
56 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
