Problem with CPU
I want to know if I can put better CPU than this CeleronM-380(Dothan1.6)
into my computer. It is really slow one and I can't find answer in Google or in Toshiba's manual. Can you help me?
  • haxdwawin Jan 04, 2009
    Here comes the CPU-Z registers dump.txt (Parts of course)
    Mainboard Model Satellite L100 (0x4A4 - 0x3694BD00)
    Processors Information
    Processor 1 (ID = 0)
    Number of cores 1 (max 1)
    Number of threads 1 (max 1)
    Name Intel Celeron M 380
    Codename Dothan
    Specification Intel(R) Celeron(R) M processor 1.60GHz
    Package Socket 479 mPGA (platform ID = 5h)
    CPUID 6.D.8
    Extended CPUID 6.D
    Brand ID 18
    Core Stepping C0
    Technology 90 nm
    Core Speed 1596.0 MHz (16.0 x 99.8 MHz)
    Rated Bus speed 399.0 MHz
    Stock frequency 1600 MHz
    Instructions sets MMX, SSE, SSE2
    L1 Data cache 32 KBytes, 8-way set associative, 64-byte line size
    L1 Instruction cache 32 KBytes, 8-way set associative, 64-byte line size
    L2 cache 1024 KBytes, 4-way set associative, 64-byte line size
    FID/VID Control no
    Chipset
    Northbridge ATI RS400/RC400/RC410 rev. 01
    Southbridge ATI SB400 rev. 80
    Memory Type DDR2
    Memory Size 512 MBytes
    Channels Single
    Memory Frequency 266.5 MHz ()
    CAS# 4.0
    RAS# to CAS# 4
    RAS# Precharge 4
    Cycle Time (tRAS) 12
    Ok, so now i want to change CPU into Pentium M 740 Socket 479 because i can buy it for low price smth like 15$ so i can work longer on my notebook. Second option is changing CPU to Core Duo T2300 Socket 479 i can buy it for 17-20$. Can I do it?
  • wishmaster10 May 11, 2010
    what is the model of the motherboard you will find the model number or letters between the PCI slots (the white slots ) on the board
    Problem Solver:
  • 12 Answers
Most of the time you cant replace a processor in a laptop because the old one is usualy soldered in
Posted on Jan 03, 2009
Why the card cage fan is working faster in dell precision 380 without getting slower?
Don't try to slow down the speed if you don't know the temperature from your processor or your motherboard. Look on the web for a monitor program to see if one of them is getting real warm Like above 60 degrees Celsius. Then your fan will work as hell.
If the computer is a bit older, perhaps the cooling paste, between the processor and the cooling body on the processor is dried. Only use the correct cooling past, and not anything else. Don't allow the processor to heat up above 65 degrees Celsius, because it won't live long after that.
If you do have a monitor program, you could slow down the fan, without any risk.
Jun 15, 2014 | Dell Precision 380 Workstation Pentium D...
What CPU 'chips' can be fitted to the HP Pavilion slimline magnetite motherboards ?
according to HP's compatibility list..
CeleronM 420 (Y) 1.6 GHz
  • 533 MHz front side bus
  • Socket 479
    May 25, 2014 | Washing Machines
    I have an IBM Thinkpad 1200 and its running slow, i need to change the CPU to a faster one. What CPU is available for it?
    I think cpu changing is not wise in budgetry if really you need to make your device faster .
    if really you want to make it faster just change the motherboard and cpu to gether but still its not resionable.
    better to try and increese the ram and the use faster hard drive .
    and run only the programs only required by disabling application on startup.
    Dec 13, 2010 | IBM ThinkPad i1200 1161 Notebook
    My computer is really slow going into differnt sites....the compressor fan is slow to start up...had my computer stripped down and tuned up, but it's still slow...they said the cpu is showing its age,...
    Your computer going slow could be for the following reasons: 1 Not enough RAM - remove unwanted files by cleaning the disc. Also defragment the computer. Increase the RAM 2 Virus - remove the virus 3 If you do the above you will see the improvement and no need to have a new cpu
    Dec 22, 2009 | Computers & Internet
    Cooling fan stopped, supply overheats
    Most probably it is fried. Take out the power supply. Then test it if it will start by shorting the power on wire to ground wire for a short time. Then read the voltage readings on terminal output of power supply that connects to the motherboard 2O pins header. If within spec then change the supply fan. If not then buy another one it is more costly to repair than to buy a new one.
    If you don't know this have a friend with knowledge assist you.
    Goodluck
    Oct 10, 2009 | Antec TPII-380 (TPII380) 380-Watt Power...
    Loud noise grinding sound computer works ok. Noise seems to be coming from fan cpu area
    Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
    I would suggest getting a can of compressed air made for computers
    take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
    While you are in there just check that the CPU cooler itself is not loose
    If it is it will have to be re-seated.
    If it needs re-seating don't just take it off and put it back on as that might make things worse with your temperature problem they have to be cleaned and new thermal grease put on ($2-5)
    DON'T remove the CPU just the fan/cooler assembly.
    You must clean both the surfaces without scraping anything off. Use isopropynol alcohol and cotton bud sticks until both surfaces are clean, you can use your finger nail to scrape harder residue if you wish but nothing else.
    DON'T pour the alcohol over the CPU
    Now apply some new thermal grease (most computer shops have it)
    Be careful about how much you put on
    Here are
    some basic instructions
    Once you have re-assembled your cooler and re-connected it check everything is OK and power up the computer.
    If everything went to plan you should now be back in business
    If it the Powers supply fan then these ase sometimes replaceable.
    Beware howeve that even after disconnection high voltage may still be present.in side the PSU.
    Better to replace the whole power supply witha the same or greater wattage.
    Oct 05, 2009 | Dell Computers & Internet
    Problem Switching On Laptop
    well try to reformat your pc.. maybe a virus is attacking ur laptop. try doing this first, it may helped.
    Aug 15, 2009 | Intel Motherboard
    Hello, i want to change CPU in my Toshiba L100-119[CeleronM-380(Dothan1.6)] to better one. I have problems when finding maxium CPU approved for L100 mainboard. Thank YOU for an answer.
    it only supports up to a 533mhz front side bus(fsb)
    since you have a dothan(newer) just look for a p4m (m for mobile) processor with a 533fsb and probably without HT and under 2.8ghz to be safe (i cant say a 2.8 will work or not but at least you have a direction)
    btw any penium 4 m is faster than the celeron you have
    another thing heat will be higher, clear dust and use tiny amount of arctic silver 5
    and battery time will be down
    Jan 03, 2009 | Computers & Internet
    Slow
    Hey
    There can be many things that can cause your computer to slow down.
    First of all Viruses .. some viruses once in the computer are difficult to be recognized by normal anit-viruses they generally make your computer go slow, such a problem can be solved either by getting a better anti virus or by formatting your system
    There can be another reason... have you check how many processes are running on your comp?
    ctrl + alt + delete go to processes... now a normal XP os needs only 17-20 applications to run properly ... so anything in excess to it is being run on your computer to provide some sort of service to you(you must not start stopping those extra processes w/o knows what they are doing).Try closing some of the applications this should make your computer work faster
    There can be another reason... the drive space in your OS drive Say Drive C is very less ... should be above 500 Mb for smooth functioning.. in such a case delete unwanted files..
    for further assistance feel free to mail me at
    kushalagarwal22@gmail.com
    Cheers
    Kushal
    Aug 27, 2008 | Dell Inspiron 1100 Notebook
    Computers & Internet Logo
    115 people viewed this question
    David Payne
    David Payne
