Question about Brother IntelliFAX 5750e Laser Fax
Sleep How do I get our fax out of sleep mode. I can't receive or send faxes when it is in that mode.
  • 26 Answers
You should be able to send and recieve faxs in the sleep mode. You need to reset the machine, pull out the plug, hold down the menue key while you plug the machine in. When maintanence comes up in the display enter 01 and wait. Whwn maintanence comes up again press 99. DO NOT PRESS ANY OTHER NUMBERS OR YOU WILL DAMAGE THE MACHINE BEYOND REPAIR. Your fax is now reset and completley empty, you will have to put in your name etc and sleep mode will be set to "0" minutes
Posted on May 20, 2007
  • 22 Answers
SOURCE: "Receiving Sleep" on Brother Fax 4100
The sleep mode is only a power save mode. You may not have the machine in the correct fax receive mode. If the machine is on a line by itself it needs to be set to fax only, if line is shared with a telephone it needs to be in fax/telephone, if you share the machine with an answering machine it needs to be in TAD mode, and so forth. Each time you press the MODE key it will change the receive mode. Most people hit this key by mistake and change the MODE and the unit will not pick up calls. Press the MODE key until you are in the correct mode. To make sure the machine will print, press reports and then the 1, this will print a help list. If the help list prints you know that the machine works. Then check to make sure the machine is in the correct fax receive mode.
Posted on Oct 04, 2007
SOURCE: How can we exit Sleep mode?
what was the password to remove form the sleep mode
Posted on Sep 04, 2008
  • 9 Answers
SOURCE: able to receive fax but cant send
sleep mode is just a status of the machine when it is in idle mode.you cannot turn this off however you can delay the time before the unit goes into a sleep mode.it has nothing to do when you are sending out faxes.so here are a few things you need to check when sending a fax (1)dial tone by pressing hook/hold button (2) insert the doc into the adf, make sure it will change to "enter fax # and start,or copy press copy (3) dial the number (4) wait for fax tones of the receiving unit before you press start. now if you can hear an operator on the line,that has to be verified with your phone company since brother machine does not restrict incoming and outgoing faxes UNLESS that is restricted from your phone line.
Posted on Nov 19, 2008
goalie39
  • 472 Answers
SOURCE: Sleep mode
Have you tried to unplug it, and leave it out for a few minutes, then repower, this clears the volitile memory.
Ed
Posted on Apr 26, 2009
greg_margo
  • 1959 Answers
SOURCE: Sleep mode will not disable, even when send button
Press Menu 1,8
then set minutes to 00
press Stop/Exit
This should disable Sleep mode. Please post back with any questions or to rate this solution. Thank you very much.
Greg
Posted on Aug 11, 2009
The fax continually registers as being in "sleep" mode. Says it's in "Sleep" mode all day even when it is receiving and or sending out. How do I correct that?
Setting the Sleep Mode reduces power consumption while the machine is idle.
You can choose how long the machine is idle (from 00 to 99 minutes) before it drops into sleep mode.
The timer automatically resets itself after the machine
receives a fax or PC data, or makes a copy. The default setting is 5 minutes.
1 Press Menu, 1, 8.
2 Use the Dial pad to enter the length of
time the machine is idle before it drops
into sleep mode (00 to 99 minutes), and then press Set.
3 Press Stop/Exit.
Jun 15, 2010 | Brother IntelliFax-4100e Fax
Our fax is on sleep mode...how do we get it off that mode and able to recieve faxes?
you can tun it off by using the settings setup . it should send and receive even in sleep mode
Jan 08, 2010 | Brother IntelliFAX 5750e Laser Fax
My machine is also set to sleep mode and cannot rcv. faxes!
Sleep mode does not affect the reception of faxe check receive settings instead
Aug 28, 2009 | Brother IntelliFAX 2800 Laser Fax
My fax machine sends faxes, prints, and received faxes but the faxes are blank. We have been trying to figure out the problem and while fiddling with the machine have actually received a successful fax???...
Probably not. You can change that setting in the user modes in menu/function and set it to 99 minutes. HAve you tried another drum unit? Your charge corona wire in the drum unit maybe broken!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleep mode will not disable, even when send button pushed, paper put in for fax or receiver taken off hook. Sleep mode set to default 5 minutes.
Press Menu 1,8
press Stop/Exit
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Our Brother Intellifax 3800 will go to sleep and ignore attempts to send or receive faxes. It will take a docment into memory and go to sleep and not send it or the phone will ring with an incoming fax and...
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
hth,
razors
Mar 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Sleepy fax
Scroll through the SETUP menus, look for ENERGY SAVER or SLEEP
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Able to receive fax but cant send
Nov 18, 2008 | Brother IntelliFax-2820 Laser Fax
Aug 28, 2008 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 5750e Laser Fax Logo
548 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
