Question about Nintendo Chicken Shoot for Wii
Gun wont shoot from trigger - Nintendo Chicken Shoot for Wii
    Genius:
  • 2,432 Answers
Check for broken or worn out micro switch.
Posted on Oct 30, 2012
How do I shoot??
Point gun toward target and place finger on trigger. Pull trigger.
Feb 22, 2015 | Cars & Trucks
59 winchester 12 ga winlite
I should shoot al lot more that twice. I have put thousands of rounds through my shotgun. If it shoots twice with a single pull of the trigger, you have an illegal machine gun, most likely due to a broken part in the trigger assembly. Get it fixed before you shoot it again. Right now the penalty for even possessing such a device is 10 years in jail.
Numrich gun parts may have the parts you need.
Firearm Parts Accessories Military Surplus Numrich Gun Parts
Feb 07, 2014 | Optics
DOESN'T FEED,IT MIGHT MISS SHOOT A TIME OR TWO THEN GET A NAIL THEN NOT FEED.I'M SHOOTING A 1.5"TECO NAIL. ANOTHER GUN DOESN'T SHOOT EVERY TIME LIKE THE DEPRESSOR ISN'T LETTING THE...
Usually miss feed happens when the driver does not return to top position not allowing the nails to feed into position. Easy to check, point nose of nailer up then down again to see if the driver is loose in the cylinder. If loose, the driver will be in the down position when the side door is opened. If driver is down, replace driver oring. If driver oring is good, look for spring tension on feeder and check feeder spring on the door side. If piston oring good and feeders have good spring tension, suspect lower bumper cracked(remove head and piston to check bumper).
On gun with depressor (safty foot) not actuating trigger, look for worn trigger (trigger inner lever could be worn) or loose or worn firing pin in the trigger valve above the trigger(valve # tva6). Replace as needed. To check for proper gun action, remove the nails, remove the 3mm roll pin holding trigger and dry fire the gun by depressing the tigger pin. Good luck
Sep 21, 2011 | Stanley Bostitch Coil Framing Nailer
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
New electric arrow stapler et501. Will shoot a staple but when you reposition to shoot a second wont always fire off. Sometimes can shoot 2 or 3 in a row and then then will not shoot. gun does not...
Check the instructions for cleaning and lubrication tips. Sounds like you have a buildup of the adhesive that holds staples in "sticks," and it's keeping the staple stick from moving forward into the firing position.
Oct 16, 2017 | Heavy Duty Arrow Et501 Electric...
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
I have a hitachi nv 65 ah that will shoot two nails at time
I hope this doesn't offend you. What I'm suggesting is that you may not be using your nail gun correctly. Some people keep the trigger pulled and bounce the gun onto the wood. This technique works okay, but placement accuracy of the nail suffers. The other technique is to place the gun on the wood and pull the trigger USING TWO HANDS! This is the technique suggested by the manufacturer. The problem with this technique is that if you apply insufficient pressure to the gun (USING ONE HAND) the safety is not engage so you don't shoot a nail. What usually happens - I just witnessed this a couple of weeks ago - is that not enough pressure is applied while pulling the trigger so you push harder and end up bumping the gun which shoots a nail - because you have the trigger pulled, but the nail shot was a surprise so it causes another bump (and is more apt to bounce because you're using just one hand). Because it is a machine and can operate faster than your reflexes - it shoots another nail. This happens before you can lift it off of the wood, or remove your finger from the trigger. That's the reason I keep the trigger pulled and bounce it. I know that after the bounce I've set a nail, and can remove my finger from the trigger. When I need to accurately set a nail I always use two hands, press hard and pull the trigger, and release quickly. Only pull the trigger when you know you're about to set a nail, and are poised above the workpiece.
Dec 09, 2009 | Air Tools & Compressors
My daisy buck 400 shot repeater bb gun wont shoot
bazthespazz i would like that file you said, just bought the daisy buck 400 and got jammed arround the first 20 shots nd i want to repair it but its hard to remove the piece of the trigger
Jul 30, 2009 | Toys
Nintendo Chicken Shoot for  Wii Logo
57 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
