Question about Dryers
My Kenmore Electric dryer (model # 110.64994301) Will not heat.  We have been looking online for answers and have seen where the electrical circuit fuses may be blown.  I can't find the fuses on the dryer.  Help
Jimster
  • 240 Answers
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Posted on Feb 02, 2008
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
rdial54
  • 14 Answers
SOURCE: Kenmore dryer (electric )
replace heat relay
Posted on Sep 07, 2008
  • 97 Answers
SOURCE: kenmore electric dryer (model # 110 60202990)
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 25, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer model 110.60942990 no
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible by removing the lower toe panel dire the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites2.gif I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Nov 01, 2009
Any known issues with the Kenmore Elite He4 Electric Dryer 11085089400?
Besides the thermal fuse, the thermistor, main control board, door locking system and the problems all over youtube and google, the dryer may last you about a year or so. That is if you only do laundry one a year. The HE4's are ****. Have both washer and dryer for about 5 years. I could now be a sears repair man with the amount of knowledge I had to digest while fixing these things. NEVER, NEVER again will I buy kenmore!
Sep 27, 2012 | Kenmore Elite HE4 Electric Dryer
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
I have a Kenmore Dryer model #110.66732500 that just quit heating. Everything else is working fine, tumbles but no heat. It is 4.5 years old. When it quit it tripped the circuit breaker, we reset the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
bn
Sep 28, 2010 | Kenmore Dryers
Kenmore electric dryer model 68702894 turns but no
The heater element may have failed - however, first check the Thermal limit fuse on the rear of the machine (silver disc held by 2 screws). Check for continuity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 28, 2010 | Kenmore 60172 Electric Commercial Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
