Question about Zyxel HomeSafe HS-100W Wireless Router (HS100W)
I cant go back to defaults in my zyxel hs 100 w router, so i my conectivity is limited or nule what can i do??????
  • 340 Answers
To perform a factory reset:
Power off the router,
Hold down the recessed reset button on the rear of the unit (keep it held down)
Power on the router with the reset button still pressed down.
You will notice all the LAN lights flash at the same time which will indicate that the router has reset - this takes up to 30 seconds.
When all the LAN lights do flash simultaneously you can let go of the reset button.
Your router is now reset.
The default IP address is "192.168.1.1" and the default password is "1234".
Now, do set the admin password again, other vice others can access your router and change the setup and set the password.
Regards
/Teis
Posted on Jan 03, 2009
My Zyxel P-600 series modem is connected to my desk top. Can i get a wireless connection to my laptop?
Yes you should! Download a manual for your router and read how you start the wireless LAN. I think you login to your router by writing 192.168.1.1 in the URL window in a web browser. Password is 1234 as default. Be sure to encrypt the AP with WPA so that your neighbours dont use your internet conection.
Aug 25, 2010 | Zyxel P660HW-D1 Router
Need default username and password
mcdevito75 here, Best Bet, see your local Staples, Best Buy or any computer store with the info about your router they should be able to help.
Jun 29, 2010 | Zyxel HomeSafe HS-100W Wireless Router...
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
I cant log in to my zyxel!(zyxel ies 1248) cos of someone change the IP address so how can i reset default?
See the attached manual and look up page 42 where is shows how to reset your router to the default settings. The default ip is 192.168.1.1.
the link is: ftp://ftp.zyxel.com/P-660HW-D1_v2/user_guide/P-660HW-D1%20v2_3.40_Ed1.pdf
If this solves your problem, leave feedback please.
Feb 05, 2010 | Zyxel Prestige 660R Router (P660R)
BlackBerry Curve 8320 will not connect with HS-100W
If it's any consolation. My BB 8820 connects to my Zyxel NBG-460N, but after a few minutes the connection just dies (the BB still shows its connected to the WiFi, tries to use it and can in fact send packets out, but it does not receive anything any more). The router has gone through 3 firmware upgrades so far and no solution. It's also causing trouble with some USB WiFi sticks when the SSID hiding is enabled.
In short: I believe ZyXEL's WLAN support is simply broken, and you'll have to buy a WLAN AP from another manufacturer.
Oct 04, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
I recently securied my router by updating the security settings and now i cant use my wireless network on my laptop could you please advise me how to disable te security on my router i'v tried logging into...
Try resetting the router if nothing works. This will bring it back to factory defaults . Once it is back to default settings, you would have to configure it again.
hope this helps
Thanks
Ranjit
Sep 06, 2009 | Zyxel P660HW-D1 Router
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
Jun 27, 2009 | Zyxel Prestige 320W Wireless Firewall...
Cant hook up
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router
insert satalite into wan port, set up router
run a client wire from the router to a zyxel PL-100
and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
http://www.zyxel.com/upload/images/app_diagram/app_pl100_550x0.gif
Apr 22, 2009 | Computers & Internet
Have to disable web encryption for my xbox 360 to work. Wont except anything i put in?
There is reset on the back of the router. Hold it in for about 10 seconds, till the lights flash. This will bring it back to default.
Before resetting the router, go to this link, select your model and the select Connect to Xbox live (network support). It will show you how to configure it.
http://support.xbox.com/support/en/us/nxe/default.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 21, 2009 | Zyxel HomeSafe HS-100W Wireless Router...
Zyxel P660HW-D1 drivers
Since you are referring to a router you can access the configuration using the web configuration you just need to type the router default ip address on your browser to access the configuration.
the default ip address is 192.168.1.1
http://www.zyxel.com/web/product_family_detail.php?PC1indexflag=20040812093058&CategoryGroupNo=AC5783AE-9475-41AD-BDA5-0997187F44AA
http://dl01.zyxel.com/DownloadLibary_ShortName/P-660HW-D1/quick_start_guide/P-660HW-D1_1.pdf
Mar 02, 2008 | Zyxel P660HW-D1 Router
Zyxel HomeSafe HS-100W Wireless Router (HS100W) Logo
233 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
