Question about Samsung LN19A330J LCD TV
Add channel to TV that I deleted (using rabbit ears w/ newish digital TV)
I accidentally deleted a channel that used to come in great w/ rabbit ears and now somehow I accidentally deleted this channel, and I can't get it back even when I manually enter the numbers When I do autoscan, it doesn't even recognize this channel anymore, but it used to come in quite well w/ the rabbit ears, so I think there really is a signal there to receive HELP
    Top Expert:
  • Samsung Master
  • 14,553 Answers
Confirm with another set if signal for that channel is still there or not--also if not too large a set take it to someone who gets the channel and add that channel back into the memory with the remote.
Posted on Oct 30, 2012
rapanSF
  • 150 Answers
SOURCE: TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Posted on Dec 03, 2008
  • 1214 Answers
SOURCE: NO DTV CHANNELS
There may be an input button on the remote, or on the TV, that allows you to switch from the standard ATSC tuner to the DTV tuner.
Let me know if you can't find it and I will dig for an owner manual. But the above should allow you to switch tuners and input sources.
Posted on Feb 16, 2009
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
  • 160 Answers
SOURCE: Receiving the sound but no picture on digital TV channels
If you are trying to watch HD TV through the tv and you are only getting sound, it is most likely because you would need an High Definition cable box. Hope it helps
Posted on Aug 11, 2009
  • 60 Answers
SOURCE: Samsung LN-T5281F TV: Control panel on TV is not responding
  1. Need to replace the main Board
Posted on Aug 23, 2009
MY ZENITH MOD DTT901 DIGITAL CONVERTER ONLY PICKS UP TWO SPANISH STATIONS, 39-1 & 2. NO LOCAL NETS. I AM USING RABBIT EARS. WHAT'S WRONG?
Do you have digital tv that pick up local channels on rabbit ears? If you do, something in the DTT 901 menu is set wrong.
Jun 30, 2011 | Zenith Analog to Digital Audio Converter
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
Sanyo model HT27547 installed to Dishnetwork satellite.
the model you listed will receive digital rf signals without the need for a converter box. the link below is a link to the owners manual for your set, in it you will see what to do to get your local station once the television signals switch to all digital broadcasts.
http://www.sanyotv.com/HT27547%20(E)%200255A-.pdf
Please take the time to rate this solution.
Dec 26, 2008 | Sanyo HT27546 TV
I have a digital TV with an outside antenna and rotor.I rcv analog channels w/o any problem.I can rcv channel 19.1 on my TV and on my old TV with a converter box. I have gone to antennaweb.com to get the...
the frequency catcher of the antenna may be weaker then required.to receive the digital channels u can attach a network booster which will solve the problem.
Dec 04, 2008 | Televison & Video
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Do I need a Set Top Box Converter?
Yes you can continue to use Rabbit ears if you are close enough to the station. Most digital stations are operationg at reduced power. Switch it to digital and let it scan for channels, you may be plesantly surprized at what it finds.
Sep 30, 2008 | Televison & Video
DTV Converter Box
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
I Can Fix It
Sep 22, 2008 | Protron PLTV-32 Television
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Samsung LN19A330J LCD TV Logo
262 people viewed this question
Henry  Thomas
Henry Thomas
