Question about GE Refrigerators
Ge tfh30pr ice
Tfh30pr ice buildup
5 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Ice buildup around freezer door seal.
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
Posted on May 23, 2009
aasc
  • 1606 Answers
SOURCE: My GE refrigerator, freezer is
Remove the food from the freezer from the icemaker down . Remove the 6 (?) screws holding the rear panel on . At the bottom below the coils , there is a drain hole . Start from the center below the coils , defrosting with a hair dryer . Eventually you'll see the hole . keep defrosting the hole until excess water starts going down the hole or if you think the hole is clear , use a small hose inserted into the hole and blow thru to remove any built up food debris in drain . After clear , reinstall the panel and frozen food .
Posted on Aug 09, 2009
aasc
  • 1606 Answers
SOURCE: ge mod.pde18lzpbww.defrost tray ice buildup every
Remove the rear panel inside the freezer . Defrost the drain tray whr=ere the drain hole is until water will flow down it . Hot water sometimes helps . Use a small hose inserted into the drain and blow out any debris . Get a Solid ALUMINUM wire about 9 inches long (14-16 guage) and put into the hole as far as possible without using force (bend the wire if necessary) and make a hook with the other end ahich you should hook onto the defrost heater . This ALUMINUM wire will keep the drain hole cleared of ice due to the transfer of heat from the glass defrost heater . Do not make the hook too tight for fear of breaking the glass covering on the heater .
Posted on Aug 16, 2009
  • 32 Answers
SOURCE: GE side by side freezer not working - ice buildup
check the defrost timmer if it is working you need a defrost heater you can manually turn the defrost timmer to check the heater the timmer turns off the compressor and on the heater 2 or 3 times a day the timmer is a box with a round knob sticking out of it turn the knob tell it clicks look under the front for it or in the back most refrigerators have a wiring diagram on the back or by the compressor
Posted on Oct 20, 2009
GE freezer Model GBS22KBSCCC / freeze is got ice building up in the bottom
Ice buildup in freezer compartment is a sign of either bad door seals or an inoperative self defrosting system.
Jun 14, 2017 | GE Refrigerators
Back wall ice buildup, fridge not cooling but freezer is fine other than ice. Back wall of refrigerator squishes with sound of water behind it. Have had it unplugged for 24 hours, ice gone.
Anytime you have ice buildup in back of freezer it indicates that the auto defrost mechanism is not working. Check the defrost timer, heater element, defrost thermostat for proper operation.
Jul 19, 2015 | GE Profile 24.7 cu. ft. Top Freezer...
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
I have a GE Profile fridge, top freezer. Ice buildup keeps blocking thew evaporator fan. I've defrosted 2x, checked evap drain for blockage. But ice buildup reoccurs after 2-3 days. Turning up the
You have a defrost problem. Locate your defrost timer while the unit is iced up and turn it until you hear a defined click. At this point open the freezer and listen for ice cracking. If Ice starts cracking then it's your defrost timer bad. If ice doesn't crack, then you have a defrost component bad ( heater and Bi-Metal) Ohm out your heating element and replace if there is no continuity. You can usually find defrost timer either under the front of the box, in the fridge around the light or thermostat or sometimes in the back at the bottom. The dial on the timer can only be turned one way with a large flat head. You will hear the difference in the way the clicks sound for the defined click. Good luck.
Mar 09, 2013 | Refrigerators
GE profile refrigerator pss266msra has a problem with the freezer. Replaced the thermistor and heater as suggested since I had ice buildup. Now icemaker is leaking water which is freezing into icicles -...
One of two things is happening.
1) the fill tube leading from outside the box into the icemaker may have ice buildup or is too close to the icemaker fill wall. Make sure there is a gap between fill tube and wall and check for ice in the tube.
2) wait for the icemaker to call for water and see how long is calls water for. It is only suppose to be 7.2 seconds. If it calls for water longer it can be overflowing. If overflowing than replace icemaker.
Usually there is ice buildup or something that the water is hitting and splashing everywhere.
If you have anymore questions or need more assistance please comment.
Aug 01, 2011 | GE Refrigerators
Refriger not cold but freezer is cold
Your defrost timer is inside the fresh food compartment and behind and inside the control panel. Part number WR09X0489. I will show you a photo location. Be right back, Sea Breeze
Apr 08, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
My GE refrigerator, freezer is a side by side, model # TFH30PR - 1994 purchase. Sudenly I am getting ice build up on the freezer floor. My research suggests a plugged drain hole - but I cannot find the...
Aug 09, 2009 | Refrigerators
Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
Jun 04, 2009 | GE GSS25JEMWW Side by Side
Thanks
Vic
May 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Jul 26, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
